Old 01-03-2012, 07:40 AM   #1
2ndtimess
2ndtimeSS
2ndtimess's Avatar
Drives: 2010 2SS 6 speed Infernal Orange
Hurst Shifter With Hurst Shift Boot
Just Finished install with modified Hurst shift boot on 2010 SS
Name:  Hurst Rubber Boot.JPG
2ndtimess is offline   Reply With Quote
Old 01-03-2012, 07:42 AM   #2
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
This looks great. Is the throw super long? By the looks of this picture, the shift knob rides much higher than the stock setup.
Hannibal is offline   Reply With Quote
Old 01-03-2012, 07:56 AM   #3
2ndtimess
2ndtimeSS
2ndtimess's Avatar
It is a short shift kit, with a different stick (higher) It sits higher than the standard stick you get with the kit but still comfortable to shift. The throw is much shorter (takes a few to get used to) Compared to factory shifter much tighter (seems like in neutral when in first) took some work to make the boot work in the factory opening, had to add a piece to the front of the boot to fill the void.
Old 01-03-2012, 08:09 AM   #4
Hannibal
Hannibal's Avatar
Do you have any better pictures than the one you posted?
Old 01-03-2012, 08:29 AM   #5
2ndtimess
2ndtimeSS
2ndtimess's Avatar
Took that pic with camaera on phone over the weekend. Will try to get more detailed pics to post this week.
Old 01-03-2012, 09:15 AM   #6
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Hi. I employ a subtle retro theme with my car and as a result, I am extremely interested in doing this setup, except with the stock leather shift boot and the T-handle I currently run. Can you link me to the Hurst stick you're using?
I'd be interested in that kind of boot as well, if you could PM me your instructions, I'd appreciate it.
nUcLeArEnVoY is offline   Reply With Quote
Old 01-03-2012, 12:16 PM   #7
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
Looks great!
BTW- any of the Hurst upper sticks will physically fit on the aftermarket Hurst Shifter. From the picture, it looks like you're using our Hurst p/n- 1144580 for the boot: http://www.hurst-shifters.com/?wpsc-...-plate-1144580
Kenji is offline   Reply With Quote
Old 01-03-2012, 12:23 PM   #8
2ndtimess
2ndtimeSS
2ndtimess's Avatar
That is the one, Had to do a little fabrication to the boot to fill the void, since the opening on the manual shift is a little more oblong than square. Just added a piece to the front lip of the boot. Now if Hurst had a rubber shift boot that was a fit I think you would get more sales. I am sure you would have to find a way to attach it to the factory center console once you remove the OEM bracket with the leather shift boot.
Old 01-03-2012, 12:48 PM   #9
dianeokie
Going places
dianeokie's Avatar
Originally Posted by Kenji View Post
Looks great!
What if I got the kit, but have a V6 with a different shift pattern than the one on the knob that comes with the kit, any suggestions?
Old 01-03-2012, 03:50 PM   #10
2ndtimess
2ndtimeSS
2ndtimess's Avatar
The Hurst billet short throw shifter is rated for both V6 and V8 2010 Camaro and up should all be the same and you can still buy other aftermarket shift knobs with the Hurst kit, as well as different sticks
Old 01-03-2012, 05:11 PM   #11
krabtree13
krabtree13
Drives: '10 S.W. 2SS/RS w/I.O. stripe pkg
i got my hurst short-throw shifter last week.haven't installed it,but i'm curious as to why you didn't use the stock boot ?
krabtree13 is offline   Reply With Quote
Old 01-04-2012, 10:54 AM   #12
2ndtimess
2ndtimeSS
2ndtimess's Avatar
The stock boot did not fit with the retro look I was looking for. Actually used it initially then after I really looked at it went for the Hurst boot and adapted it to fit the Camaro
Old 01-04-2012, 11:48 AM   #13
Kenji
Kenji's Avatar
Contact customer service at (818)483-1366. They may be able to work something out with you.
Old 01-04-2012, 12:38 PM   #14
RallyYellow11
RallyYellow11's Avatar
Drives: Nothing
I got the kit for mine, i have the V6, did not matter to me. I put the knob on anyway, but i decided to go back to the stock knob.
RallyYellow11 is offline   Reply With Quote
Will the White Classic Hurst Shift Knob fit the "Factory Hurst Shifter" on the SS? TCAT 5th Gen Camaro SS LS LT General Discussions 28 04-10-2012 09:36 PM
Rubber Boot For Hurst Short Shifter 2ndtimess 5th Gen Camaro SS LS LT General Discussions 26 12-16-2011 06:40 PM
Hurst Shifter Review on 2SS linkwpc Vendor and Seller review / feedback / experiences 22 06-15-2010 08:27 PM
MTI Racing Shift Boot Retainer MTI Racing Kevin Transmission / Driveline 1 06-01-2010 09:56 AM
Comments on my Hurst Throw Shifter Blueclyde V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 03-19-2010 04:46 PM
