Old 01-03-2012, 09:04 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Flashing CEL
Go out for a cruise. Punch it a couple times at 60mph. Stabilatrac and Traction control off and when I punch it the CEL flashes. Is reset by turning car off and starting and if you let it run enough it will go away without turning car off. Car didnt seem to run any different. Any ideas?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 01-03-2012, 09:05 PM   #2
jsharp
jsharp's Avatar
This has happend twice since colder weather have never had this happen at all before now
Old 01-03-2012, 09:06 PM   #3
jsharp
jsharp's Avatar
I have noticed in summer a/f runs 11.1 to 11.6 under full boost. Now in colder weather it showing 12.1 not sure if this is due to temp change or if it has something to do with this flashing CEL. HMMM>
Old 01-03-2012, 09:20 PM   #4
Steck
Drives: 2006 twin turbo Corvette Z06
It's telling you there's a misfire condition.
Steck is offline   Reply With Quote
Old 01-04-2012, 07:15 AM   #5
jsharp
jsharp's Avatar
Cause? Ideas?
Old 01-04-2012, 11:34 AM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
YA what he said lol.
If its not misfiring, your misfire table needs to be rescaled
Tampa Tuning is offline   Reply With Quote
Old 01-04-2012, 12:36 PM   #7
jsharp
jsharp's Avatar
so is this something I can scan/log and send to my tuner? I understand it means misfire but I dont understand what kind of things cause that? Bad plug, plug wire, maf issues ect? If its in the tune then I would think I could log that and send it to the tuner correct?
Old 01-04-2012, 12:47 PM   #8
Swytch
Swytch's Avatar
Drives: 10 2SS/RS Black, 99 Daktota
Should be able to, yeah. Just be careful. I have been reading up on boosted engines as I am starting to plan my build for the summer. My understanding so far tells me that if your engine is misfiring and you arent boosting, its not a huge deal, but should be looked at. Same situation with boost, especially at WOT, that could be REALLY bad..
Id log the snot out of it with a hand held tuner when its happening and then at least review the logs and see what the engine/ECM are doing during these events, might give you a better idea of whats happening and weather the tuner will be able to help or not..
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
Swytch is offline   Reply With Quote
Oil change caused CEL? usafboy Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 11 11-23-2011 07:07 PM
CEL and Stabili Track Flashing boro62 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 08-25-2011 04:53 PM
Cure for the CEL ?! 5thGENv6 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 02-12-2011 07:13 AM
One possible solution to CEL P0430 w/ JBA midpipes Goliath Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 01-10-2011 07:55 PM
Another LT Headers and CEL for Emissions kauffjd3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-29-2010 02:54 PM
