Old 01-11-2012, 07:51 AM   #1
myold88
myold88's Avatar
AUTO TRANS WILL NOT UPSHIFT
My 2010 SS with an automatic trans (16,000 miles) will not go back into 6th gear after slowing down. This happens when on the highway at 70-75 MPH.
All is fine until I must slow down for any reason, and then accelerate back up past 60 to get back to 70 or better. It then stays in 5th gear.
AT about 70 MPH my tach reads about 2000 RPM in 6th gear. In 5th gear my tach then reads well over 2200 even at 65.
To get the car to go back into 6th gear I have to shift into Sport mode, then manually upshift back to 6th gear. Then all is fine back in D until I slow down again.
I had it to the dealer who could find nothing wrong. I'm planning on going back again this week.
Has anyone else had this problem with their A6 ?
Old 01-11-2012, 11:55 AM   #2
Chevrolet Customer Svc
Drives: GM Vehicles
I'm sorry to hear about this old88. Have you taken a dealer tech for a ride with you to show what the vehicle does while driving at the speeds you mentioned? That might be the best way to go about this. I hope they're able to find the problem and get it taken care of for you.
Jeff Morris, Chevrolet Customer Service
Old 01-11-2012, 07:44 PM   #3
white ZL1
Drives: none
Triple check fluid level.
white ZL1 is offline   Reply With Quote
Old 01-12-2012, 06:59 AM   #4
myold88
myold88's Avatar
When I brought the car in for the oil cooler leak they checked the trans fluid at that time.
that's the first thing I thought of. I've made an appointment at the dealer for Monday.
The tech will road test the car on the interstate with me. Hopefully I can duplicate the problem with him.
Old 01-12-2012, 07:47 AM   #5
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Never experienced that problem, good luck and keep us L99 guy's posted..
KARBON is offline   Reply With Quote
Old 01-12-2012, 09:19 AM   #6
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
so you took it to the dealer, replicated the problem, and they told you there was nothing wrong?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 01-12-2012, 12:05 PM   #7
myold88
myold88's Avatar
No. The dealer checked the trans fluid and only hooked up the computer while it was in the shop and found nothing.
This Monday they will actually road test it with me on our local interstate.
Old 01-12-2012, 02:18 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Why did they "check" the trans fluid level if there was no trans fluid leaking?
Who knows what they did.
The trans fluid level will be good for 100,000 miles at least, if there is no visible leak!
Rock-It Man is offline   Reply With Quote
Old 01-12-2012, 03:11 PM   #9
myold88
myold88's Avatar
Just like white SS/RS above said- The fluid level was the first thing the dealer's transmission tech said he would check. It could have been low from the factory
Besides there was fluid leaking under the car but it was from the oil cooler. That was a gasket leak which apparently is a common problem and the dealer repaired.
Hopefully Monday I can duplicate the problem with the tech in the car.
Old 01-20-2012, 09:08 AM   #10
myold88
myold88's Avatar
As an update: The dealer contacted GM and apparently I'm the only one who has had this problem. I had it on the Interstate twice and tried to duplicate the problem without success. I'm not sure but I guess that's a good thing.
I'll see how it is in the Spring when Im back on the road.
Old 01-20-2012, 09:35 AM   #11
cb2011rs
cb2011rs's Avatar
Drives: 2018 1SS 1LE
posted in wrong thread .
cb2011rs is offline   Reply With Quote
Old 01-20-2012, 10:50 AM   #12
SC2150
A mis-fire detected will keep it from going into lock-up mode, but that would have shown on the scan as a stored code. It will also show as a flashing CEL indicating a misfire.
Fuild level is critical but you have covered that.
We run diagnostics in real time while test driving and can command every shift & lock-up and watch in real time what is happening. If you were closer I would tell you to stop in
Old 01-20-2012, 11:05 AM   #13
myold88
myold88's Avatar
Thanks for the info and I'll keep your co info as I may be driving my SS to Sarasota Fl soon.
Old 03-05-2012, 10:47 AM   #14
JeffP
Drives: 2010 ABM 2SS/RS
I am also experiencing this problem. Did your dealer resolve this issue?
JeffP is offline   Reply With Quote
Camaro ZL1 Laps Nurburgring in 7:41.27. Enters Supercar Territory!! Tran Camaro ZL1 Forum - ZL1 Specific Topics 547 11-15-2011 02:53 PM
Dip Stick Auto Trans 6L80 cowboy1948 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 08-02-2011 10:34 PM
Z28- will it come in an auto trans too? faninc Camaro ZL1 Forum - ZL1 Specific Topics 37 10-08-2010 09:49 AM
Consensus Feb 6th Plus lots of other key dates UCF w00t 5th Gen Camaro SS LS LT General Discussions 16 01-23-2009 12:39 AM
