ALWAYS-N-BOOST
Help..Speedo Font Change MOD, where can I get this done
Kinda dont like to read Upside down....
Anyone no where I can get the MOD or One similar.... I like how the actual font has changed dont care about the backround colors just the Font itself Thanks in Advance |
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
I would be interested in this Mod too.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
Get a 2012 cluster.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
ALWAYS-N-BOOST
<----------------- I have a 2012 Cluster
#6 |
![]() Drives: 2010 1ssrs Join Date: Apr 2009
im interested too
#7 |
Sorry. So what is it you want the 2012 font in a different color? Or did you want the older 2010-11 font style?
#8 |
ALWAYS-N-BOOST
Maby I should Correct my self, the font is fine...the placement is where the issue is.....see how 0mph is upside down 20mph is sideways same all the way up then 140mph is also side ways and 160 is totally Upside down....now look at the 1st pic I posted
#9 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2008
Just use the digital readout in the center between the tach and speedo (Driver Information Center)
#10 |
![]() Drives: Something less than a Camaro Join Date: Jan 2012
Izach26, that interior is from the Camaro Black Concept presented during SEMA 2008. My brief search has not revealed any sources for purchasing similar gauges.
http://www.camaro5.com/forums/showthread.php?t=9271 |
#11 | |
knows 2 facts about ducks
#12 |
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
I'm surprised no aftermarket company has come up with gauge overlays to look like the concept.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
That was going to be my suggestion too.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#14 | |
I like teeth.
Drives: #198 Join Date: Oct 2009
| Tags |
| dash gauges, gauges |
| Easy to change the cluster from US units to metric? | yockey | 5th Gen Camaro SS LS LT General Discussions | 20 | 08-27-2018 10:54 AM |
| DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 07:11 PM |
| First oil change and a long trip soon | angie7 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 12 | 06-13-2011 11:06 PM |
| 18 inch to 20 inch wheel swap - computer speedo change? | TheHorse13 | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 10-06-2010 12:08 PM |
| Your thoughts on the Speedo and Tach in the 2010 Camaro dash? | SlasherMcGee | 5th Gen Camaro SS LS LT General Discussions | 51 | 03-06-2010 11:13 AM |
