Rubbing Noise Coming From Brake
I noticed a rubbing noise coming from the front passenger brakes. It sounds like the brake is rubbing, but I cant exactly put my finger on if its normal noise or not. Its been difficult figuring out what circumstances it occurs in, but it seems like it only happens when the brakes are cold. Its not the usual squeal that happens when stopping, it just sounds like something is rubbing against the disc when I'm driving. Anyone else hear of this? Could it be a pebble got under the brake pad? Should I take it to the dealer get it checked out? It hasnt caused any noticeable problems, its just an annoying noise I'd like to go away
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Getting a quick check at your dealer should be what reveals the culprit on this mystery! I hope it's a quick check up for you and while you're there maybe they can run a full check for full clean bill of health for your Camaro.
Jeff Morris, Chevrolet Customer Service |
Thanks for the input. Will it cost me any money, or will it be covered under the warranty?
| Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 | TAG UR IT | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 58 | 12-01-2019 09:54 PM |
| Popping Noise Coming From Drivers Seat | WVCamaro10 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 05-30-2012 08:35 AM |
| Brake noise? | Fhabercrombie | Suspension / Brakes / Chassis | 2 | 05-25-2011 10:19 AM |
| Screeching noise coming from rear of 2010 RS LT2 Camaro | Matt79M | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 03-25-2011 10:38 AM |
| A6 people, clicking noise coming out of park? | SDCamaro10 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 9 | 05-09-2010 12:01 AM |
