![]() ![]() ![]() ![]() Drives: fast Join Date: Jul 2010
no hose access - how to wash?
I've watched & re-watched the Adam's + Junk Man videos and do my best to follow the proper technique. I don't have access to a water hose to wash my car and therefore cannot foam. What is my alternative?
![]() ![]() ![]() ![]() Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS Join Date: Oct 2011
A number of self service wash bays will have an option to set the wand to foam. I'd recommend that to start. You may have to do a little leg work to find the right one, but most should have it as an option.
You might want to check out some of these relatively new "waterless" wash products.
Link to a demo: http://www.autogeek.net/dp-waterless...ncentrate.html
"Never argue with a fool, onlookers may not be able to tell the difference." - Mark Twain "Never argue with an idiot, they drag you down to their level and beat you with experience" - Unknown |
#4 | |
Good luck!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
YOu can't afford a water hose?
#6 |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
the hose isn't the problem.....its connecting it to a water source that the problem he has. I'm guessing he lives in an apartment....and many appertment complexes won't let you wash a car on their property.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Two bucket method at the local coin wash. I've done that for years on all my cars, works great.
One of the tricks is to wax before winter, this will help keep the winter road grime from sticking so bad. |
#8 |
Just a car guy
Drives: 2016 Durango R/T AWD Join Date: Oct 2011
Waterless wash is your friend.
You do have to be careful using it if your car is really dirty. The more dirt on the car while using a waterless wash of any kind, the more you can scratch the paint. I would find a touch free car wash at a gas station, and run it through that. Then take it back to your place and give it a good wipe down with some good detail spray. Be mindful, those types of carwashes do have chemicals in them that can cause damage to your paint if used extensively. I would also try and find a hand car wash (usually 15-20 bucks though) and go that route once a week. I know the feeling of not having access to a hose of any kind, it really blows man.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE 05 GT - Sold 03 Cobra - Gone (Never Forgotten) |
#9 |
![]() ![]() ![]() Drives: 2013 1SS Camaro and a truck Join Date: Apr 2011
I would suggest...two bucket wash at a car wash, or see if one of your friends would let you wash it at there place.
#10 |
![]() This is what I do too. It works perfectly.
[B]
#11 |
![]() Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
OP: Your post says that you have no hose access so you can't foam. Are you able to fill buckets and wash at all? If you mean that you have no access to water, that's a different story. In which case you need to go to a car wash like others have indicated.
It's my understanding that foaming, in general, is meant to provide added LUBRICATION more so than offering any sort of cleaning effect. The car wash soap isn't like a degreaser that's breaking up dirt, it's just sitting there. With that in mind, you can accomplish the same thing by just dunking your clean mitt in several times and squeezing it out over the panels of the car. I generally squeeze out 3-4 full mitts over the top of the car before the mitt ever touches it. If you really want to get crazy, just make up a second bucket of fresh soapy water and pour/throw it over the car before you start washing with your mitt (3 bucket method?). Your car doesn't know that the soapy water wasn't gently sprayed over it by a foaming gun. |
#12 |
![]() ![]() ![]() ![]() Drives: 2012 45th Camaro, 2SS/M6 Join Date: Mar 2011
optimum no rinse. you put it in a bucket of water and do one panel at a time. no swirl marks for me and i use it every time, 100% of the time, and i have a water hose. it's easier than conventional washes by a large margin, and it's much cheaper than conventional washes too. also at least 3,000% easier than going to a local car wash as others have suggested.
http://www.autogeek.net/optimum-no-rinse.html ![]()
#13 | |
Virologist in the making
Drives: 2010 VR SS/RS LS3 Join Date: Aug 2009
6000, Delivered to the customer - 12/21/09 ![]() |
#14 | |
![]() Drives: 11 SS(sold),96 Mustang,12 Silverado Join Date: Dec 2010
| Tags |
| adams, foam gun, junkman |
| Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 124 | 02-05-2024 10:55 PM |
| Coin operated car wash in Silicon Valley | wally_bear | USA - California | 4 | 01-16-2012 02:33 AM |
| First Adams 2 Bucket Wash at a Coin-Op | Smitty77 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 8 | 06-14-2011 09:14 AM |
| Does your Maggie EVAP hose look like this and does it bother you? | alfie43 | Forced Induction - V8 | 16 | 06-25-2010 12:30 AM |
| The ZTS Exotic Wash Show: Saturday, July 26th 2008 –DC Metro Area-www.zerotosexy.com | speedg1rl | USA - NY / NJ / PA | 2 | 07-25-2008 08:41 AM |
