![]() ![]() ![]() Drives: S/C 2SS/RS Camaro-6M-VicRed Join Date: Aug 2009
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Does your Maggie EVAP hose look like this and does it bother you?
Look at the attached photos. Note the hose that goes from the EVAP solenoid to the Magnacharger. Is it just me, or do you also have a problem with the way the hose is routed over the jack shaft. It's not touching the rotating shaft, but it's really close...too close.
Just doesn't look right, and to me, it detracts from the appearance of the installation. It actually looks worse first hand, more than the photos show. I have had several people point it out and ask "What's up with that?" When my wife commented on it, at that moment I knew it wasn't right. She's not dumb (a lawyer), but she doesn't know a supercharger from a battery charger and she spotted it. The hose barb on the body of the Maggie should have been a 90* fitting and pointed down to route the hose under the jack shaft. I called Magnasun and they told me that the hose barb was pressed in the casting. I have a machine tool background and I know that if it's pressed in the casting with a shrink fit, removing it will "bugger up" the hole...so I ain't trying that. One way or another, I will come up with a solution and get that hose rerouted....if you're interested, stay tuned. Alfie
I used to be Dragoneye...
What if you used a 90* boot and male/male fitting to re-route it? You'd have some seams, but it might look better than it does right now...
...although it doesn't really bug me. But I don't have to live with it.
You need ADM Performance's Heater Hose Relocation Kit that includes a new Evap hose as well..
Check it out below: http://www.admperformance.com/produc...50&product=210 |
![]() ![]() Drives: 625 rwhp red jewel ss COTW 11-8-10 Join Date: Oct 2009
I don't have a better picture yet, but look at my signature.you can see mine goes under! call Andy at ADM performance and I'm sure he can get you all the parts you need!
![]() Drives: GTO Join Date: Sep 2009
I don't think it looks that bad...
#6 |
Mine was installed under.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout 2011 2nd Place Fastest 4 5th Gen LSX Shootout |
#7 |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
I never understood why Magnacharger routes that hose as shown, over and so close to the transfer shaft. Looks very amaturish. Most of the installs that are done at ADM Perf use a 90 degree elbow routing the hose down. Looks better and eliminates any rub on shaft.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
#8 |
I'm not totally useless..
It used to! But for 20.00 in parts from Kragen I re-routed it under. As well as the pcv line to the intake tube. The parts are 2 packages of 90 deg elbows and 2 packages of 6" of hard line with a 90 at one end and a straight at the other. A little creative cutting and voila! You can see it somewhat here and if you want better pics let me know...
#9 | |
I think I have a solution and I'm working on it tonight. Alfie
#10 | |
The hose relocation kit is actually by TechAfx, a Michigan company and they distribute it to ADM and the other performance houses. Alfie
#11 |
Just trim about 3/8" off the elbow at the nipple end. I used a hard line/elbow part I found at Kragen to run straight down, then when I connected the line from the car, I re-routed it a bit and left it about a 1/2" long so it has a little "push" to it and between that and the shortened elbow it clears perfectly. Let me know if you need pics...
#12 | |
#13 | |
I have a "fix" to my original post and will post pics later. Alfie
#14 |
Hello!
Hrm...never noticed it before but yeah, mine is like that as well.
Look forward to your "fix"! |
