Old 02-01-2012, 08:58 AM   #1
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
New Cylinder HEad: Engine Coolant Air Bleed Plug
When installing new cylinder heads it is recommended you install new engine coolant air bleed plugs into the rear coolant passage of the cylinder heads. Has anyone done this or have experience? I'm looking for a good thread or maybe some sort of write-up. Also if someone is willing to point me in the right direction for buying the parts that would be appreciated too. Thanks!
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
Old 02-01-2012, 10:17 PM   #2
ztsmith86
ztsmith86's Avatar
Is it even necessary to install new ones when replacing the heads? Can you just swap the plugs from the stock heads into your new heads? Thanks
Old 02-01-2012, 10:48 PM   #3
ztsmith86
ztsmith86's Avatar
I bought a set of ported ls3 heads. Casting number 0821
Old 02-01-2012, 10:51 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Just swap your stock stuff over.
SUX2BU is offline   Reply With Quote
Old 02-01-2012, 11:02 PM   #5
blackonblacksls
Drives: 2011 2ss/rs
You ever seen the stock ones? I wouldn't even know how to get them out. I had to drill them on the ls7 heads I used on my car.
blackonblacksls is offline   Reply With Quote
Old 02-01-2012, 11:09 PM   #6
ztsmith86
ztsmith86's Avatar
Hmmm. So I'm still confused people seem to be saying conflicting statements here.
Old 02-01-2012, 11:28 PM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I don't think you are talking about the same thing we are. You just take a 10mm socket (or wrench), remove the four bolts holding the two rear plugs/front cross over and reinstall on your new motor.
See above.
Old 02-02-2012, 12:50 AM   #8
blackonblacksls
Drives: 2011 2ss/rs
I'm saying my heads didn't have the block offs bolted in. There were actual plugs pushed down into the heads. That I had to drill out.
See above.
bleed, coolant, cylinder, heads, plug
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17976 12-27-2021 01:07 PM
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 11:49 PM
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
Anyone cutout the mail slot? Wasp 5th Gen Camaro SS LS LT General Discussions 26 10-01-2011 08:15 PM
RAM AIR MYTH OR TRUTH JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 06-19-2010 12:41 AM
