Old 08-09-2011, 10:29 AM   #1
Wasp
Wasp's Avatar
Drives: 2011 Camaro Victory Red 2SS/RS
Anyone cutout the mail slot?
Has anyone made it into a real mail slot to push air toward the engine? If you have what do you think the gain in horsepower would be? +2?
2011 LS3 Bone Stock 1/4 - 12.841 @110.69
LS3 + CAI (no tune) 1/8 - 8.27 @ 89
Wasp is offline   Reply With Quote
Old 08-09-2011, 10:50 AM   #2
faSSt
**Sold n' Sad**
faSSt's Avatar
Drives: 11 F150 Supercrew FX4 5.0
wondered the same thing, just to give the engine a little extra air in the compartment to cool.
Wouldnt gain any HP, your intake uses it own scoop from the front of the car; aftermarket ones are sealed from the engine bay heat. I guess its possible to give a little more air to an OTR intake...
2011 Camaro 2SS, SIM, 6M, HUD, 10% tint, black out lenses, SS emblems, TSP 304 LT's, Roto-Fab, MGW shifter, gto res, 8K BFXENON, HP Tuners, Redline Fluids. ***Sold*** Now in an 11' F150 supercrew FX4.
Still addicted to the this forum
faSSt is offline   Reply With Quote
Old 08-09-2011, 10:54 AM   #3
Wasp
Wasp's Avatar
It is just a little disturbing to me that it is a fake mail slot. It looks cool but it makes me feel stupid when people tell me its a fake mail slot.
Old 08-09-2011, 10:58 AM   #4
Tysen
Tysen's Avatar
Drives: 2011 RJT 2SS/RS M6
Trade in for a ZL1. It's faster and has no mail slot.
"I'm a man who discovered the wheel, and built the Eiffel Tower out of metal and brawn! That's what kind of man I am." - Ron Burgundy
My build thread
Tysen is offline   Reply With Quote
Old 08-09-2011, 11:01 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
I'm not going to promise that I'll find Mindz's post where he explains that ram-air hoods don't really do anything until you are going roughly 150+. But I'll look for it. Basically he explains how ram-air hoods are a cosmetic mod and not a performance one. So you wouldn't see any gain in HP
Click to view my build thread
Old 08-09-2011, 11:03 AM   #6
The Stig
The Stig's Avatar
Found it
Originally Posted by Mindz
Marketers just can't resist it. Ram air! The words themselves summon up images of rushing wild beasts, or of secret military aircraft operating on futuristic principles.
Unfortunately, on most perofrmance cars, ram-air is as functional as tail fins were on cars of the ’60s.
What is it? Ram air just means using a forward-facing air intake to gain some extra intake pressure. We have all, as children, felt the pressure of moving air on our hands when we held them out the window of the family car. When moving air is brought smoothly to rest, the energy of its motion is converted into pressure. Motorcycles went through a "ram-air" period in the early 1990s, during which street bikes were equipped with the forward-facing "rocket-launcher" engine air intakes seen on many road-racing machines.
While it's appealing to imagine the forward velocity of a car being converted into free supercharge, the actual air pressure gain is extremely small at normal speeds. For example, at 150 mph, the pressure gain when air is efficiently brought to rest is 2.75 percent. Because this is a dynamic effect, it is proportional to the square of the air velocity. At a more realizable automobile speed of 75 mph, the effect (again with 100 percent efficient conversion of velocity into pressure) will be only one-quarter as great — that is, just under seven-tenths of one percent.
In fact, velocity energy is not converted into pressure at 100 percent efficiency. A figure of 75 percent efficiency is usual, which reduces our notional ram-air gain at 75 mph to one-half of one percent.
Therefore, at normal speeds, ram air is a myth. However, something much more interesting lies behind it, ignored by the advertiser's busy pen. That something is airbox resonance.
In order to implement ram air, the carburetors or throttle-bodies of our engine must seal to an airbox whose volume is large enough that the intake cycle of one cylinder cannot pull its internal pressure down significantly. Box volume is typically 10-20 times the engine's displacement. Then the forward-facing air intake is connected to the box. When this assembly is tested on the dyno — even without an external fan to simulate the high-speed rush of air past the intake — it is discovered that the engine's torque curve is greatly altered, with new peaks and hollows.
Why? The answer is airbox resonance. If you hold the mouth of an empty bottle near your open mouth as you loudly hum scales, you find that at certain “hum frequencies” the bottle reinforces your humming, which becomes louder. What is happening is that the springy compressibility of the air in the bottle is bouncing the slug of air in the bottle's neck back and forth at a particular frequency — higher if the bottle is small, lower if it is larger. Your humming is driving a rapid plus-and-minus variation of the air pressure inside the bottle.
The same thing happens inside a resonant airbox. The volume of air in the box is the “spring” in this kind of oscillator. The mass of air in the box's intake pipe is what oscillates. The “humming” that drives the oscillation is the rapid succession of suction pulses at the carb or throttle-body intakes. If the volume of the airbox and the dimensions of the intake pipe(s) are correctly chosen, the airbox can be made to resonate very strongly, in step with the engine's suction pulses. The result, when this is done correctly, is that the engine takes air from the box only during the high-pressure part of its cycle, while the box refills from atmosphere through its intake between engine suction pulses. This produces a useful gain in torque.
Using this idea, motorcycle engines have been able to realize torque increases, in particular speed ranges, of 10-15 percent. In race engines, it is usual to tune the airbox to resonate at peak-power rpm to increase top speed. For production engines, it is often more useful to tune the box resonance to fill in what would otherwise be a flat-spot in the torque curve, resulting in smoother power and improved acceleration.
Early resonant airbox systems used long intake pipes that terminated in forward-facing intakes. More recent designs do not connect the ram-air pipe to the box at all, but terminate it near the airbox entry. The actual entry pipe is a short piece of tubing with bellmouths on both ends. This is done because (a) the potential gain from actual ram air is too small to worry about, and (b) it's easier to tune the airbox with a short tube.
Where vehicle speeds are very high, gains from ram air are significant. This was discovered by Rolls-Royce in the late 1920s as the company developed its R Schneider Trophy air racing engine. At speeds above 300 mph, it was noticed that the R’s fuel mixture leaned out enough to cause backfiring. When the mixture was corrected for ram-air pressure gain, the engineers realized they had a "free" source of power. At 350 mph the gain from ram air is almost 15 percent. Similar mixture correction is necessary when ram air is used on drag-race and Bonneville cars and bikes.
Intuition suggests that a forward-facing intake made in the form of a funnel, large end foremost, should somehow multiply the pressure of the air, resulting in a much larger pressure gain at the small end. Sadly, intuition is wrong. In order to convert velocity energy into pressure, the air has to be slowed down, and this requires a duct that widens rather than narrows. Next time you fly on a commercial airliner, note that its engine intakes widen as the airflow approaches the compressor face. Such widening passages are called diffusers, and they are universally used in the conversion of velocity into pressure.
Language often plays tricks on us — especially when language is used by product advertisers. "Ram air" sounds much more appealing than "resonant airbox." Nevertheless, it is airbox resonance that actually generates a significant power gain.
Cliffnotes:
-Ram Air a myth? = NO
-Does it work on a road car = NO
-At 150mhp there is next to no gain.
-Significant gains arn't seen until 300mph+
-The air box is the key, not the ducting.
-When buying a CAI/induction kit look for the one that uses air box resonance
Edit: Additional Reading
Intake temperature is a whole different ball game.
The simple rule is:
'Cool for power (maximum charge density), hot for economy (minimum charge density to reduce losses due to throttling).'
Although in many cars the under bonnent temperatures are no where near as bad as many people beleive. This refers to a 5.3 liter Jguar XJS V12. So a big engine in a small engine bay.
The under-bonnet air temperature at idle can easily get up around 70 C but the faster the car goes the lower the air temperature falls - simply because the radiator is passing its heat to a much larger quantity of air per second - so at 80 mph. the engine is breathing air at around 45 C. That's still a bit higher than the ideal but not nearly so bad as many people think. Obviously the standard arrangement helps to maximise economy in moderate speed urban cruise without compromising top end power too much.
In setups that duct cool air from outside. The power gains from such a system are almost certainly attributed to the filter, and less restritive intake (meaning quite simply a bigger opening), and a form of air box resonance coupled with a 'cool air intake' from outside the engine bay. Sadly even at very high speeds (well over 100mph) I doubt that it has any form of 'Ram Air' effect. If you reconfigured the system to take air from the inside of a wheel arch it would produce the same results as having the intake ducts at the front of the car. The source of the air, not the location of the ducts is the important factor.
Remember the only way to get a greater volume of air into the engine is to compress it. This is what turbo and superchargers do. An air intake scoop either on the front of a car or on the bonnet will not compress the air at any speed most people are likely to travel at.
Taking the airbox resonance theory futher with the intake manifold itself by optimising the length and entry profile into each of the tracts to better exploit induced harmonic resonances in the air as it flows towards the cylinder. Any tube containing air can be made to resonate at certain critical frequencies in the manner of an organ pipe. Such is the case with the inlet tracts of an engine and if the natural resonance frequencies can be matched to the engine speed then a mild supercharging effect can be induced. Get it wrong and the reverse will apply, resulting in a loss of performance.
Old 08-09-2011, 11:06 AM   #7
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
This has been discussed before. Basically, if you were to open up the mailslot, you still have the hoodlatch behind it and the radiator and structural support.
Here's one thread from the past (there are others, too, if you want to do a search to read more about it):
http://www.camaro5.com/forums/showth...light=Mailslot
LoneStar is offline   Reply With Quote
Old 08-09-2011, 11:25 AM   #8
Wasp
Wasp's Avatar
Thanks for the quote and links. Im going to avoid the cutout
Old 08-09-2011, 11:35 AM   #9
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
I know...hate the fake mail slot and I'll add the quarter panel grill to that...Although, I like the way the mail slot looks...Would take some serious fabricating and creativity to make it happen. A lot of guys are throwing led lights in there to make it somewhat functional
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 08-09-2011, 11:56 AM   #10
bthomp01
bthomp01's Avatar
Drives: 2010 2SS/RS IBM M6
This. There's no reason for it to be open if the air is just going to plow into the hood latch anyways.
2010 IBM 2SS/RS - T BRUTAL
Matte Black Bumblebee Stripes - Unpainted Heritage Grille - Blacked Out Bowties - Stainless Works S-Tube Catback - CAI, Inc. Cold Air Intake
Whiteline Rear Cradle, Rear Differential, Front Radius Rod Bushings - BC Racing BR Coilovers - Installed by Whiteside Customs
bthomp01 is offline   Reply With Quote
Old 08-09-2011, 12:12 PM   #11
FastEddie
Drives: 2010 IOM LS3 2SS/RS Camaro
aw crap...not THIS AGAIN.
FastEddie is offline   Reply With Quote
Old 08-09-2011, 12:28 PM   #12
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Yea, I was just about to say...you can cut if out if you wanna keep your hoodlatch cool. if you pop the hood and look at it, it's pretty obvious.
On a sidenote....I didn't bother reading the superlong quoted post above as to why ram air doesn't work....but my 3rd gen picked up a solid 1.5 mph in the quarter mile when I made the ram air hood functional. So if its not supposed to work....I dunno why it did. Why were the Ss and ram air trans ams faster too? Weird.
Heres a pic of my home made not supposed to work ram air:
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 08-09-2011, 02:55 PM   #13
mouse
mouse's Avatar
Drives: 2011 2ss/rs conv, L99/Automatic
Such Knowledge! I feel so stupid now.
mouse is offline   Reply With Quote
Old 08-09-2011, 03:25 PM   #14
bthomp01
bthomp01's Avatar
Don't! We all have questions and the only reason I knew anything about the hood latch is because my Dad, who worked intimately with the production of the 5th gen from 05 to late 08 (he never got to see the line in production before retirement :() had told me when I asked the same question.
This is a great place to learn about not just the 5th gen, but general vehicle dynamics as well. I found the Ram-Air posts just as informative
clear/smoked mail slot filler 2kformula Cosmetics and Lighting Modification Discussions 1 07-15-2011 10:24 AM
Mail Slot for the V6 The ultimate Good Guy Cosmetics and Lighting Modification Discussions 62 03-08-2011 09:44 AM
Where does the mail slot come from? ColorBlind 5th Gen Camaro SS LS LT General Discussions 46 01-01-2011 05:39 PM
2010 Camaro KITT scanner lights for SS mail slot Spaceballone Exterior Parts & Accessories 1204 05-24-2010 11:02 PM
Knight Rider Light China Clone for non mail slot owners. Wizzer Cosmetics and Lighting Modification Discussions 2 05-02-2010 11:37 AM
