Old 02-08-2012, 05:07 PM   #1
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Question Rattling and knock sensors...
Until I can hunt down this damn non stop rattling from the rear can the knock sensors be safely tuned out?
After a fuse pull (5 and 22) the car runs like a raped ape until I drive about two blocks down my bumpy street and then the performance drops off tremendously.
I have the SCT X3 from JRE.
tramtwo is offline   Reply With Quote
Old 02-08-2012, 05:09 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
you don't want to turn knock sensors off
POWERFREAK is offline   Reply With Quote
Old 02-08-2012, 05:18 PM   #3
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Ok, how about turning them down? The rattle is NOT cause by the exhaust and is proving to be a real mutha hunting down.
Old 02-08-2012, 06:32 PM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Talk to your tuner. Are you sure that's the problem? I'm no tuning expert, but I've never heard of that happening (and the roads around here really suck). The fuse pull is just resetting the fuel trims, it's not like it's a permanent power-adder. I would figure out where the rattle is coming from though.
Old 02-08-2012, 06:41 PM   #5
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
Fix the problem, if you turn the knock sensors off you will regret it because then you will never find the actual cause, and then you will have a real issue and it will be too late.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 02-08-2012, 06:48 PM   #6
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
You need to find it. It can even happen after a tune because the Knock Sensors are constant and super fast. So if the condition persists then the car will be dumbed down until the cause is taken care of.
Need proof.
http://www.camaro5.com/forums/showth...=105015&page=2
Old 02-08-2012, 08:13 PM   #7
SC2150
Knock sensors are your friend.....look at the "piston carnage" thread for pics of what CAN happen if messed with. Now if your only running on the track and your 110% sure the tune is correct then we turn them off for consistancy, but that is VERY controlled conditions, fuel, tune, etc.
What catchcan are you running? Most let enough oil through to still cause detonation. ANY oil ingestion into the intake air charge is detrimental.
Old 02-08-2012, 08:19 PM   #8
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Rx
Old 02-09-2012, 04:13 PM   #9
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
How much knock are you seeing when you scan? And do you see the knock show up when you hear the rattles? Does the power drop like this when you are on the stock tune?...Just curious
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-09-2012, 04:19 PM   #10
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Great questions, I have just begun trying to deal with this. The dealer can't find the rattle, blames my muffler delete. I have had it in the air and cant find it either. The rattle is only present going over bumps, and small bumps at that, sounds like the driver side rear.
This is where I am at in the process.
Search 'rattle' on this site and about a thousand threads are returned.
Old 02-09-2012, 05:39 PM   #11
Phantom.5SS
Hell yeah I'm Guilty.....
Phantom.5SS's Avatar
Drives: 2010 2-SS ABM NON-RS
Loose brake pad????
Tap lightly on some things with a RUBBER malet...could be a heat shield as well?
Phantom.5SS is offline   Reply With Quote
Old 02-09-2012, 05:42 PM   #12
PQ
Booooosted.
PQ's Avatar
My rotor shield in the rear came lose and was rattling.
But you are right. It could be a TON of things.
Old 02-09-2012, 05:44 PM   #13
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Thanks checked all the easy obvious stuff think I would have found it by now. I just don't have enough knowledge about the suspension setup to know what I am looking at.
The fact is that it is loud enough to trip knock sensors and have the car running like crap.
Old 02-09-2012, 05:53 PM   #14
PQ
Booooosted.
PQ's Avatar
Having chased down a few noises on my car I get your frustration.
Took me a while to find them.
Used a set of Chassis Ears on my suspension to find one.
Do you have any aftermarket suspension mods?
Engine Knock 3.6L DjfunkmasterG Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 52 08-01-2011 11:40 AM
