Old 02-16-2012, 05:16 PM   #1
Cpanthers85
Drives: 2011 Camaro 2SS RS
Problems with Royal Purple Oil Filter
In October I did my first oil change on the car. Switched to Royal Purple Oil and a Royal Purple Filter. The last week of January, I put headers/tune/CAI on the car.
SO I go into my garage the other night and much to my dismay, I find about a 1/2 quart of oil puddled under the car. So my first reaction is "$&#@, I broke the rear seal or the camaro is suddenly on her period and pissed because of valentine's day...someone else has been taking my attention".
I climb under her and start checking things, and my Royal Purple Filter is litterally one turn from being off. I know it was tight. I did it myself. Talk about a disaster waiting to happen!
1) I've been on the dyno.
2) I've taken at least 9 passes in her.
3) And I'm about to add a blower.
So first question. Anyone have similar issues with their royal purple filters "unthreading"?
What Filters are people running if you are running a "high performance" motor oil?
thanks in advance.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 02-16-2012, 05:26 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
thanks in advance.
did you prelube the seal prior to install? how calibrated is your arm?
I piss excellence
and fart awesomeness
Old 02-16-2012, 05:55 PM   #3
Cpanthers85
Pre-lubed the seal and re-adjusted the calibration on my arm. This wasn't my first rodeo.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 02-16-2012, 05:58 PM   #4
ron10
Drives: 2010 2SS IOM L99
i use the mobil1 filters.
Old 02-16-2012, 06:21 PM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
AC/Delco UPF48R
Tighten by hand, then use wrench for additional 1/2 turn.
Old 02-16-2012, 06:28 PM   #6
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Are you sure the previous oil filter gasket didn't stick to the engine when you removed the old filter.
A "double" gasket does exactly what you have descibed
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 02-16-2012, 06:30 PM   #7
Cpanthers85
Originally Posted by clg_98ta View Post
AC/Delco UPF48R
I am going to go this route.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 02-16-2012, 06:34 PM   #8
Cpanthers85
Nope... and the gasket wasn't split either. It was the weirdest thing. I had a spare royal purple filter, so I threw it on there. We will see how it holds up.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 02-16-2012, 08:57 PM   #9
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
I use the same RP filters and never had a issue! Hard to say what really happen.
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 02-16-2012, 10:10 PM   #10
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Had a little help possibly ?
Could it be that you had a little help there ? Been changing my oil and filters for 50 years and never had one back off.Just does not sound right.Been on all that time and no leaks and with all the additional runs at the strip, it should of leaked prior.i would be keeping a real close eye on it including a locking gas cap !
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 02-17-2012, 08:57 AM   #11
Grabber
Just a car guy
Grabber's Avatar
Drives: 2016 Durango R/T AWD
Never had an issue with an RP filter. I've been using them for 2 years on 2 different cars. Sounds like it wasn't completely tightened (not saying you don't know how to install an oil filter) or it was a bad filter.
Hopefully the next one you put on works without issue.
Sent via morse code through a fax machine.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE
05 GT - Sold
03 Cobra - Gone (Never Forgotten)
Grabber is offline   Reply With Quote
Old 02-17-2012, 10:53 AM   #12
Cpanthers85
Well, so far, and with about 30mi on the new RP filter (the one I had laying around for the next oil change), no leaks. Must have just been a fluke with the old filter.
Buzzy- My dad said the same thing! I did the change myself.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 02-17-2012, 02:17 PM   #13
Andy@AMSOIL
Drives: 4 wheels
I use AMSOIl EA filters. they are a nano fiber that filters down very small particles, the design of the filter is also very heavy duty.
I usto use WIX
Andy@AMSOIL is offline   Reply With Quote
Old 02-17-2012, 04:04 PM   #14
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
I use K&N filters. Never a problem.
Bo Tie 1 is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
DIY Royal Purple oil change for $35 Pep Boys! BAWLZ SS Camaro DIY & HOW-TO instructions & discussions 2 02-16-2012 04:09 PM
1SS V-6 OIL PLUG LOCATION ? Brendon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 01-29-2010 01:05 PM
