Old 02-16-2012, 10:33 PM   #1
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
Need help removing harmonic balancer bolt on l99
I am installing a Maggie on my L99 (auto) and need help pulling the haromnic balancer bolt, so I can install a lil jig to drill and pin it .when I try to loosen it the whole thing turns so I removed the fuel pump fuse put the car in gear thinking O THIS WILL WORK!!! So any body have a idea what to do I have till sunday night cause monday I have a dyno appointment!!Another idea is can i finish the install and have the tuner shop pin it for me???
BowenSS1 is offline   Reply With Quote
Old 02-16-2012, 11:02 PM   #2
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
I buzzed mine off with an impact, to install it however is going to be another issue for you since you shouldnt install it with an impact because it needs to be torqued down.
When I installed mine I put it in gear and pulled the e-brake and had a buddy stand on the brakes while I tightened it down. But mines a manual, otherwise your going to have to get the tool that locks the flywheel in place. And that involves removing the starter, which really isnt a big deal.
Oxtar41 is offline   Reply With Quote
Old 02-16-2012, 11:21 PM   #3
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
i just did mine and i have a manual transmission. I pulled the starter and found a hole in the flywheel they drilled for balancing the flywheel. just so happens my air chisel bit fit perfect and snug in the hole. I turned the flywheel and made sure I had a firm resting spot on the bell housing. Or if you have a trusted friend to hold a adequate flat tip screw driver will work also. also I've seen others use vise grips in such a way, so that the lower part of the v of the jaws captures a tooth and clamped in place. This only works if you can capture a tooth, because the jaws them self will not hold it. I have headers so this wasn't an option. not enough room. or you can buy the tool. but the parts stores don't carry them from my experience. dealer item or kent moore I assume. I did see another manufacture selling them too.
lionssfan is offline   Reply With Quote
Old 02-17-2012, 12:02 AM   #4
BowenSS1
BowenSS1's Avatar
Thanks guys for the response!!!!Any l99 guys out there or vendors that give advise or shed light on my problem!
Thanks
Old 02-17-2012, 02:33 AM   #5
lionssfan
lionssfan's Avatar
I would hold the flywheel even though you have a auto trans. I wouldn't put that much stress on the drivetrain and trans. and weather you use a impact to take it off or not you still need to hold the flywheel for going back on. the 50 nm torgue plus the 120 degrees I think it was is a lot....you will find out. your going to need a long breaker bar plus a pipe or cheater bar on that for degrees. it's a bitch to tighten. Just make sure have a good hold on the flywheel how ever you do it.
Old 02-17-2012, 10:33 AM   #6
BlkSlvrdo129
Drives: 2008 Silverado
I used the kent moore J-42386-A, awesome little tool.
BlkSlvrdo129 is offline   Reply With Quote
Old 02-17-2012, 11:24 AM   #7
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
Air Impact is the easiest
MudderFinger is offline   Reply With Quote
Old 02-17-2012, 11:49 AM   #8
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
I went out and bought a new 750ft/lb impact and that wouldn't budge mine... I ended up getting a large chain and chaining the harmonic ballancer pulley to the frame. turned the crank with a breaker bar until the chain was snug then used a 4ft breaker bar to get it off.
This was the worst part of my install. took me about a day to get that bolt off, then the rest was a piece of cake...
good luck
AngelSpeedFreak is offline   Reply With Quote
Old 02-17-2012, 12:36 PM   #9
camslambam
Drives: 2010 SS, 06 SRT10 Ram
opened up the hole under bell housing.
jammed crowbar in.
problem solved.
camslambam is offline   Reply With Quote
Old 02-17-2012, 12:44 PM   #10
EliteCZM523
EliteCZM523's Avatar
Drives: 2010 2SS/RS
Impact Gun is the way to go to remove the bolt, but please DON'T use a impact gun to reinstall it.....not the correct way to do it!!!
Use a flywheel locking tool, or otherwise prevent the flywheel from spinning as some others above me suggested!
Good Luck!
EliteCZM523 is offline   Reply With Quote
Old 02-17-2012, 06:39 PM   #11
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
I put a propane torch to mine to heat it as it would not budge. Once hot I used an impact and it came right off.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 02-17-2012, 09:17 PM   #12
BowenSS1
BowenSS1's Avatar
Thanks for the help and advise guys called my tuner and ask them to do it for me when they do the pulleys and tune Mon.
Old 02-18-2012, 09:41 AM   #13
Stingr69
'69 Owned Since '79
Stingr69's Avatar
THIS!!!
You can buy them used on Ebay and sell it back when you are done if money is a problem. This tool is a huge help when swapping a cam or installing a supercharger. I decided to keep mine. You need it several times during the tear down and supercharger install. This is the GM specified tool for the job. I also bought the Kent Moore installer tool used which is pretty sweet. The balancer puller was a free rental from Autozone. They also free loan the 200# click type torque wrench that you will need. No torque angle meter but still a good option.
-Mark.
Old 02-18-2012, 09:52 AM   #14
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
Use a strap wrench or a chain and bolt to hold the balancer in place. I changed my timing belt on my 4Runner and the bolt had to be torqued stupid like 300 ft lbs. I had to borrow a strap wrench to hold it in place. Easiest thing to do is what others mentioned and find a way to hold the flywheel or use an impact.
Drew10 is offline   Reply With Quote
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 06-02-2020 01:51 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
Vid - ECS L99 Stage II bolt on package results East Coast Supercharging Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 12-01-2009 07:27 PM
SLP's Underdrive Harmonic Balancer - $179.99 tbyrne V8 Bolt-Ons & Tunes 2 11-29-2009 11:03 AM
Harmonic balancer removal w/o impact wrench MJ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 11-05-2009 12:13 PM
