Old 02-19-2012, 04:35 PM   #1
starbase
starbase's Avatar
Drives: 2011 Camaro LS SIM
Heater Fan Ticking Sound
I had a ticking, jingling sound coming from the heater vent for some time. I was pretty sure it was coming from there since it was worse when the fan was at the lowest two speeds. It mostly stopped when I turned the fan off.
I brought the sexy beast in for a regular oil change and told them about this sound. After they were done, the receipt said that they cleaned dirt and debris from the blower motor cage. The sound is gone - at least for now.
Does anyone know where the blower motor cage is located. I'd like to know so that I can periodically clean it myself?
starbase is offline   Reply With Quote
Old 02-19-2012, 05:29 PM   #2
01CamaroF1WRC
Drives: 2001 Camaro V6, 2010 Camaro 2SS RS
I’ve only had my Camaro for a few months and been noticing the same or similar noise. When I listen to the radio I hear winding, gearing noise coming from the speakers or the front dash. It occurs when my heater is on the lowest level of 1, 2, or 3. When I turn the heater (fan) off, the noise goes away. I’m not due for service to later summer/early fall, so if I can clean it myself, that would be great. I don’t know where the location is either.
01CamaroF1WRC is offline   Reply With Quote
Old 02-19-2012, 11:20 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The HVAC blower fan is located behind the cabin air filter. Here is a link on how to remove the filter:
http://www.camaro5.com/forums/showth...BIN+AIR+FILTER
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 02-20-2012, 02:20 AM   #4
liquidsmoke
Two Miles An Hour
Drives: SIM 2LT RS
Have the same sound. Once you hear it, it's pretty annoying and have turn the air either up or off to make it stop. I thought it was normal to be honest. Glad to know its not, and i can prob fix it myself.
expect nothing, but take everything
liquidsmoke is offline   Reply With Quote
Old 02-20-2012, 08:35 AM   #5
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
I just had my blower motor replaced this weekend for the same issue. It is more of a common issue and if you complain about it and demonstrate it to the dealer they should replace the core.
The chirping at the lowest two notches was annoying as heck for me. It was hard to reproduce it in the dealer garage because my exhaust was loud, but once I took them outside they could hear it. It's even more noticeable if you're driving and you don't really hear your exhaust.
cab2g is offline   Reply With Quote
Old 02-20-2012, 10:20 AM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
You will get dirt, leaves, etc in there, hard to avoid
Old 02-21-2012, 04:52 PM   #7
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
I knew I wasn't the only one with this problem. I'm taking mine in to get fixed. I thought it was lubrication issue like on my older car.
I'll let you guys know how it goes.
TastyBake is offline   Reply With Quote
Old 02-22-2012, 12:38 PM   #8
TastyBake
TastyBake's Avatar
Well,
The HVAC motor is actually molded into the plastic. They have to order it. It comes with an installation ring to hold it in place.
Old 02-22-2012, 01:16 PM   #9
bowtie628
Auto body and paint guy
bowtie628's Avatar
Drives: 2010 Camaro LS
i have the SAME problem.. when i have the fan on LOW.. i hear a noise that sounds like a jingle.. makes me nuts!!
bowtie628 is offline   Reply With Quote
Old 02-26-2012, 08:44 PM   #10
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
Same here as far as the problem. I am going to follow the thread posted by LimaCharlie and try cleaning the cabin filter and blower motor cage to see if it makes a difference. Ill let you know how it works out. I dont trust the dealer to do it right.
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
BigBlue2010 is offline   Reply With Quote
Old 02-27-2012, 08:36 AM   #11
Carriccp
Carriccp's Avatar
Drives: Sold
Please keep us updated, I have the same thing in my 2011. :(
Carriccp is offline   Reply With Quote
Old 04-21-2012, 03:17 PM   #12
starbase
starbase's Avatar
Diagram request
When I first asked about cleaning the HVAC blower fan, LimaCharlie wrote back with a link showing how to remove the filter
The link is no longer there. Can someone repost?
Thanks.
Old 04-25-2012, 11:01 AM   #13
starbase
starbase's Avatar
Diagram request
I found the diagram on another page within Camaro5 at
http://www.camaro5.com/forums/showpo...01&postcount=1
There's also a youtube video on replacing it at
"http://www.youtube.com/watch?v=ymul7T3hC5Y"
Here is the diagram plus an additional diagram I found elsewhere
Old 04-30-2012, 02:59 PM   #14
Ericschaefer13
Drives: 2011 2SS
Just had mine replaced, for the second time. The first time the cut the cowl to big and jb welded the fan back in, took it to another dealer and they had to pull the windshield and dash to repair the cowl. 3 weeks in the making. Just got it back. They installed motor kit # 22762719, this is the new updated kit. Dealer said they are having bushing issues with the stock fan making it chirp. The bolt and plate to mount the fan do not come in the fan kit, they had to order them separately. Glad this was covered under warrenty!
Ericschaefer13 is offline   Reply With Quote
So let's set this straight on what gives it that v8 sound CamaroC-17 5th Gen Camaro SS LS LT General Discussions 112 01-03-2017 12:06 PM
Ticking sound in the engine compartment BloodUSMC 5th Gen Camaro SS LS LT General Discussions 8 05-07-2011 10:39 PM
v6 ticking sound from motor. strauchpete Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 05-15-2010 10:46 AM
Audio Basics The_Blur Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 01-17-2010 06:07 PM
Surround Sound Help! T! E! X! A! S! Off-topic Discussions 3 01-24-2009 06:55 PM
