Old 03-03-2012, 11:08 AM   #1
PSDSAINT
Drives: 2011 Camaro SS Black
CAGS WASTES GAS!!
CAGS is put on all Camaro, 6 Speeds to get more Miles Per Gallon. I think it works exactly the opposite! Let's face it, CAGS is a PITA to us guys with 6 speeds. Here are your options. 1. Get a CAGS killer and get rid of CAGS. (I have one and will be installing this summer) 2. Shift at a lower RPM so the CAGS doesn't kick in. (drive like an old lady) 3. Go over the RPM range so the CAGS is over ridden and doesn't kick in. (this is what I do most of the time), AND THIS BURNS MORE GAS!! This is exactly the opposite of what the intent of CAGS is, right? Its to bad the Government tries to shift for us and get us to save gas because this CAGS thing just doesn't work to save gas, it really makes us burn more gas, IMO!!
PSDSAINT is offline   Reply With Quote
Old 03-03-2012, 11:27 AM   #2
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Um...No....
1.)CAGS saved you from a gas guzzler tax.
2.)Its easily defeat able with a $20 plug.
3.)If you shift when it tells you instead of avoiding it then you SAVE gas. Thats it's intended purpose.
4.)It takes 10 minutes to put a skip shift eliminator in.
Gm 1 You 0
Obzen is offline   Reply With Quote
Old 03-03-2012, 11:45 AM   #3
PSDSAINT
Sorry I did forget about the gas guzzler tax! Good point! I'll still stick with the rest of what i said.
Old 03-03-2012, 12:55 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
and keep in mind that the reason it makes you skip 2nd and 3rd is the same how an automatic transmission car will not always go thru every single gear, but will jump up to 3rd or 4th in order to increase efficiency when taking off from a stop then leveling out at a typical road speed ~35-45mph.
I piss excellence
and fart awesomeness
Old 03-03-2012, 12:57 PM   #5
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
First thing I got rid of.
calbert1999 is offline   Reply With Quote
Old 03-03-2012, 12:57 PM   #6
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Originally Posted by Obzen View Post
Um...No....
Gm 1 You 0
This isn't just a Camaro thing. The Corvette has it also.
And as stated, it does work if you use it as intended.
But most (myself included) bypass it.
But CAGS allowed these cars to pass government fuel economy tests without having to endure a gas guzzler tax.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 03-03-2012, 12:59 PM   #7
Z/28orSs
Z/28orSs's Avatar
Drives: 2000 ss
i dont have a problem with cags and i have had it for 8 years.....
all you have to do is shift above 2.3K RPM
Z/28orSs is offline   Reply With Quote
Old 03-03-2012, 01:11 PM   #8
Blitz
Blitz's Avatar
Drives: 2012 CTS-V Sedan
Easily tuned out and avoid GG Tax... i'll take it.
Blitz is offline   Reply With Quote
Old 03-03-2012, 01:57 PM   #9
Nessal
Drives: Exige, Miata, Ghia
When CAGS come up and you shift to fourth it lugs the crap out of the engine. I can't see that being a good thing especially the manual specifically states not to lug the engine.
Nessal is offline   Reply With Quote
Old 03-03-2012, 02:07 PM   #10
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I never have CAGS kick in. Never. I don't have the CAGS eliminator either. This is so easy to defeat it is a non issue. It saves the gas guzzler tax so it's done it's job.
Old 03-03-2012, 03:14 PM   #11
CCbusa09
CCbusa09's Avatar
Drives: '06 Tacoma, '11 Durango, '12 SW 1SS
Until I read this post, I was wondering if I was the only one not having an issue with CAGS. Granted, I only have 1,400 miles on my new '12 SS, but CAGS has only engaged on me twice. I forgot it's even there.
2012 1SS LS3; Borla S type axle back and CAI, Inc. cold air induction.
CCbusa09 is offline   Reply With Quote
Old 03-03-2012, 03:18 PM   #12
BackinBlackSS/RS
Go Blue!!!!!
Yep, I contol CAGS, it does not control me.
Old 03-03-2012, 04:29 PM   #13
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
$2000 gas guzzler tax or $20 Skip Shift Eliminator? I will take the Skip Shift Eliminator 100% of the time.
Old 03-03-2012, 04:34 PM   #14
The Stig
knows 2 facts about ducks
The Stig's Avatar
It shouldn't and doesn't lug the engine. Well unless your going up a hill and you let CAGS engage - though that would probably be your own fault for not accelerating faster.
Click to view my build thread
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Bad gas! Camaro sputtered & died gzartman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 09-07-2010 05:45 PM
CAGS (aka: Skip Shift) Apex Motorsports 5th Gen Camaro SS LS LT General Discussions 108 06-25-2010 08:26 PM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 06:34 PM
