![]() Drives: 2010 camaro 2LT/Rally Yellow Join Date: Feb 2012
amp install question
b4 i do it the way i was going to, I have a 4 channel amp i am installing in place of the stock amp, now, that one does not have preouts, i was told to run a seperate sub amp i can tap off one set of rcas off the 4 channel amp, then put that to the sub amps rca inputs, however, my subwoofer amp seems a bit better then my 4 channel, it has a set of preouts, so my question would it matter if i ran the rcas to my 4 channel amp from the subwoofer amp preouts? Or do i have to run the sub amp off one set of the 4 channel amp? the fark harness has a front set and rear set of rcas, so i am thinking i have to run them to the 4 channel first, then split off one side to the sub amp correct?
![]() Drives: 45th 2SS LS3, 05 Ram 1500 SLT Join Date: Jul 2011
How many more threads are you going to make to ask questions that you could have asked in your others?
Does your sub amp have 4 preouts? 1 set is not enough. You could try it that way, or you could just get two of these Y adapters and plug it into your FARK, then go from there. http://www.crutchfield.com/p_142AMYC...r.html?tp=2802 |
#3 | |
![]() ![]() ![]() ![]() Drives: 2012 45th Camaro, 2SS/M6 Join Date: Mar 2011
http://www.camaro5.com/forums/search...rchid=13647371 at this rate he might get his own subforum! |
![]() Drives: 1 Join Date: Mar 2010
Ay i used to do the same thing haha, it gets more attention
![]() Drives: 2020 Satin Steel 2SS Coupe Join Date: Jan 2011
Really, each thread should be for a different topic. That way in the future when another member uses the
they can find an answer before starting a new thread or wasting time reading through every result.This is a forum, after all...
#6 |
Vaux96, thanks, thats what i will do, will try to remember to use the other threads, but they were different questions, plus it get the questions up top, nothing like having to scroll through old threads to find yours. but i see your point,
| 6x9 Install question | Lawdog86 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 08-25-2011 06:43 AM |
| L99 RX Catch Can install question | Three of Swords | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 05-08-2011 08:02 PM |
| Pfadt lowering springs - after install question | omegaman | Suspension / Brakes / Chassis | 5 | 01-01-2011 07:51 PM |
| Amp install kit | Moriartii | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 03-24-2010 01:47 PM |
| Need Help. BA Amp Sub Install | Eski7399 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 02-17-2010 08:25 PM |
