Old 03-15-2012, 01:14 PM   #1
josephs8
josephs8's Avatar
Drives: 2011 Yellow 2LT RS Camaro
Just Bought a New Amp Need Advice
I just bought a JL Audio XD700/5 D Class Amp and had some questions. I have the stock Premium Boston Acoustics System. I am replacing the factory amp with the XD700/5. I am going to power the 4 speakers (ive disconnected the center speaker) and a sub. Ive bought the JL 12w3v3-2 so I figured this would run at 2 Ohms at 300W. My question comes in at the speakers. I have read different things about the ohms of stock BA speakers. Will they run at 2 Ohms or 4 Ohms?
Also Am I on the right track here or does something sound horribly wrong with my implementation.
josephs8 is offline   Reply With Quote
Old 03-15-2012, 02:15 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
you'll be fine, get the FARK harness from ******** and rock on. I've got the JL xd400 that I replaced the stock amp with and it sounds great.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-15-2012, 03:28 PM   #3
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Yeah, you'll be fine. Since it is a class D amp, it will be smart to know what ohms to run the speakers at. But I thought that the BA speakers ran at 4 ohms
Old 03-16-2012, 09:54 PM   #4
EDGE_
EDGE_'s Avatar
Drives: 2010 1SS/RS SIM L99
That is the same setup I have, I am assuming you are trying to find out what to set the target AC voltage at, I used 14.1Vac, i.e. 2 ohms. As I understand it, the speakers are 2 ohms but the tweeter are 4 ohms. In any case, 14.1V worked great for me.
EDGE_ is offline   Reply With Quote
Old 03-17-2012, 02:08 AM   #5
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I don't know about that amp, but my Alpine PDX amps run at 2 or 4 ohm automatically. I kept the stock speakers up front for a while and they sounded pretty good as long as I didn't over power them.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 03-17-2012, 11:03 AM   #6
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Is there a way to keep the center speaker? I kind of like using the center speaker, because when I have people in the car their legs tend to block the door speakers. With the center speaker, you still get good volume up front.
Would that require a 5 channel amp?
To run the two rear 6x9s, two 6.5s in the doors, and the center front speaker?
Thanks, sorry for the thread hijack.
Old 03-17-2012, 04:36 PM   #7
Vaux96
Vaux96's Avatar
Drives: 45th 2SS LS3, 05 Ram 1500 SLT
Mainly people lose the center speaker because they cheat by using the FARK, or by just using the factory wiring that is already in the car for the speakers. It's certainly possible to keep the center speaker, but it would be more difficult. You would either have to find which wire in the factory harness goes to the center speaker and make sure power is going to it somehow, or you could do it the BEST way, and that is run your own wire to your speakers from your amplifier. You would probably have to take your dash, doors, and floorboards apart though.
A five channel amp wouldn't really work for the center speaker, because the fifth channel is usually 300 or more watts for a subwoofer and not a regular speaker. There are 6 channel amps out there that would work but it seems not a lot of companies make them. Of course you could just buy 2 amps instead.
Vaux96 is offline   Reply With Quote
Old 03-17-2012, 04:43 PM   #8
Vaux96
Vaux96's Avatar
Apparently there is some confusion as to what ohm's the stock speakers are and what load is presented to the amp because of how they are wired. I am still confused and I don't really know but apparently all of your speakers will be running at 4ohms. A lot of people here are using the amp you have (or the 4 channel version) and it works good for them. Now the sub you will wire yourself for 2 ohms so that won't be an issue.
Old 03-17-2012, 05:07 PM   #9
justa25thTA
it actually sounds much better with the aftermarket amp without the center channel. I thought I might miss it, but don't even give it a second thought any more.
Old 11-20-2012, 10:59 AM   #10
Shu71
Drives: 2011 Camaro RS M6
The center channel is in the X2 plug on the stock amp in the #3 and #4 pin positions. The ******** harness does not include the pins or wiring for that channel. I would assume one could buy the pins and insert into the X2 harness and then possibly wire it to both front channels. I think the JL XD400 type amp would be fine with those on the same channel split with the front door and tweeters.
Shu71 is offline   Reply With Quote
Replacing stock amp with XD400/4 usranger80 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 17 03-03-2012 12:34 PM
Need advice on amp a1cmatt Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 22 01-22-2012 06:27 PM
Changed Amp (PPI --> Polk Audio) Hicompression Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 02-23-2011 01:07 PM
Amp install and compartment non BA Black on Black Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 01-30-2011 01:11 PM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 01:14 AM
