Old 04-01-2012, 06:06 PM   #1
HopeRidesAlone
HopeRidesAlone's Avatar
Drives: 2010 Camaro Black 2SS/RS
SS or ZL1 Sways
Would either bolt directly up to a v6? Also how much difference would SS sways make because i know there are quite a few of those sets laying around in people garages lol and ZL1 are not quite readily available for cheap. So what do you guys think? Thanks.
2010 Black 2LT/RS - Injen CAI, ARK DTS Catback Polished Tips, OBX LT Headers, Lowered on Eibach, 3/8 blackiceolator, Trifecta Tuned.- Totaled 3/10/13
2010 Black 2SS/RS - Stainless powers 1 7/8 LT headers, cold air inductions cai, Tuned by dynosteve, Feesler side skirt, Feesler Spoiler, Feesler carbon fiber bowties, H&R Lowering Springs.
HopeRidesAlone is offline   Reply With Quote
Old 04-01-2012, 06:23 PM   #2
L99CAMA2011
L99CAMA2011's Avatar
FE4 rear lower control arms and even my stock 2012 SS sways F/R with drop springs would make your lighter V6 a happy camper.
Old 04-02-2012, 04:36 PM   #3
toehead93
Drives: 2014 2SS/1LE
New ZL1 sway bars are $110 and $115 each last time I checked online. Of course waiting for a set of tak-offs will be cheaper.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 04-02-2012, 04:46 PM   #4
HopeRidesAlone
This is the plan im waiting to see what comes available in the next few months its not a rush mod. Im trying this new thing do one mod at a time in slow intervals so i get the itch and cure it lol
Old 04-02-2012, 05:02 PM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Keep in mind that unless you own a 2012+ car, the ZL1 sway bars will not bolt up to your rear lower control arms, you will need to upgrade those as well at the same time. The 10/11 SS bars will bolt up, but the 12+ SS/ZL1 bars will not work with the older 2010/11 control arms.
Here is a copy of our sway bar comparison chart, notice the small difference between the FE2 (V6) and FE3 (10/11 SS) bar packages... especially compared to an aftermarket bar. Unless you're getting the sway bars for free or EXTREMELY cheap they probably aren't worth the effort to have a shop install them.
Our sway bars will bolt up to your current control arms, or alternatively if you want to upgrade to the FE4/FE5 (2012+ SS/ZL1) rear lower control arms we will have a specific package that will work even better that's designed for those arms. For the needs of most street cars our current Sport Sway bars will work great, and offer a fixed front and adjustable rear bar.
Below is a copy of our sway bar comparison chart with the FE2/FE3 sway bar relative stiffnesses plotted against our bars. You will notice especially in the rear that our bars are MUCH stiffer, this is to restore a much more neutral handling balance to your Camaro. From the factory there is quite a bit of understeer, and by stiffening the rear bar you can dial out quite a bit of that. A more neutral car will result in a Camaro that's much more fun to drive on the street!
FRONT
REAR
Old 04-03-2012, 01:18 PM   #6
nak3dsnake
Drives: 2010 Camaro IBM 2LT/RS M6
Yes ZL1 parts will bolt right on. You will also need to change you lower control arms for the new style rear bars. If I were you, I'd just wait for the 1LE. And add the sways from it. ZL1 is 25mm front and 28mm rear. 1LE is 27mm front and 28mm rear. The ZL1 bits are all on hold anyway so you cant get them.
nak3dsnake is offline   Reply With Quote
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 10:38 PM
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 06:22 AM
670 hp z28camaro2471 Chevy Camaro vs... 125 01-29-2012 10:43 PM
2012 Camaro ZL1 Price Announced at $54,095 MSRP ! TLSTWIN Camaro ZL1 Forum - ZL1 Specific Topics 735 12-20-2011 08:48 AM
Need help with order please zfuzz Camaro ZL1 Forum - ZL1 Specific Topics 7 11-22-2011 06:40 AM
