Old 04-08-2012, 09:14 PM   #1
NathanRobinson
NathanRobinson's Avatar
Drives: 2011 Camaro
Subs not up to par..
So I finally got my system in yesterday and the speakers sound amazing but my sub isn't anywhere near as loud as I had hoped. My mids and highs some what drown out the bass. I was wondering is it because I'm still using the factory radio? The system is an Fi Q 15" in a 4 cubic foot box tuned to 32hz off an Audison LRX 1.400 and Focal K2 comps off an Audison LRX 4.300. Thanks in advance guys!
NathanRobinson is offline   Reply With Quote
Old 04-08-2012, 11:34 PM   #2
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Yes, your factory head unit is the weakest link in your system.
=Stephens= is offline   Reply With Quote
Old 04-08-2012, 11:52 PM   #3
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I have a similar issue using the factory head unit and the FARK. With the sub signal coming from the rear channels their is less bass to be had by the time you decrease bass to avoid distortion in the other speakers at higher volume. Without a separate RCA out for bass from the head it makes tuning a bit more difficult.
I've been working so much I haven't had time to properly tune my system. Your amps should have crossovers that will allow for more bass to the subs while sending less to the others. I hope to get some tuning in tomorrow before going back to work.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 04-09-2012, 12:00 AM   #4
CWI
CWI's Avatar
BTW, I also have the K2 Focals. They sound awesome. Where did you put your tweets?
Old 04-09-2012, 12:30 AM   #5
NathanRobinson
Drives: 2011 Camaro
Thanks for the help guys! Ill have to get a head unit now. My tweets are in the factory pods
Old 04-09-2012, 12:39 AM   #6
CWI
CWI's Avatar
I didn't see any way to fit a 2" tweeter in there. I put mine in the door panels, on the left side I put mine about where the mirror button was and moved the mirror control further up the door panel then put the other in the same spot on the other side. I'm hoping I can still tune the soundstate up some. The tweets aim toward the rear more this way.
Old 04-09-2012, 08:58 AM   #7
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
I'd try going back into your amps and properly tuning them before dropping money into a head unit. Somethings not right and your HU isnt it.
PIPE
PIPE is offline   Reply With Quote
Old 04-09-2012, 09:01 AM   #8
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
probably needs to tune/adjust the sub amp setting..
Old 04-09-2012, 09:05 AM   #9
SS King
SS King's Avatar
Drives: a Panty Dropper
Should of got the BTLS
SS King is offline   Reply With Quote
Old 04-09-2012, 10:11 AM   #10
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
what source are you listening too from the stock head unit, FM, XM or flash drive?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 04-09-2012, 10:28 AM   #11
010 Camaro SS
010 Camaro SS's Avatar
Drives: 2010 Camaro SS 2SS
Previously was using factory head unit with a 10" MTX Sub - 500 Watt amp...Sounded o-k i thought...Installed recently Kenwood Multimedia Unit huge difference...The MTX amp has bass control knob...that makes a huge difference also...Something gotta be off with your set up...
010 Camaro SS is offline   Reply With Quote
Old 04-09-2012, 12:18 PM   #12
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Old 04-09-2012, 01:48 PM   #13
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
It's not in the amps. Here is the issue why you need a head unit vs factory. The Signal to noise ratio (s/n) for the stock does not match up to the s/n of the amps. Therefore you will not get the bass output possible. You can turn up the gain on the amp and what will happen is the s/n won't match up and you will blow up your subs.
Old 04-09-2012, 01:54 PM   #14
2010SLVRBULIT
even if your h/u doesn't put out adequate voltage, you can always compensate further down the electrical chain w/ signal processors/balanced line drivers, etc...but it sure helps to have a high, clean signal at the get go..and so long as you set your amp gains(levels) properly w/ your h/u volume, you shouldn't damage your speakers.
1 12 inch sub or 2 10 inch subs? atlang3lo Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 03-29-2012 03:24 PM
Pair of Memphis Mclass 15-MCP10D4 subs Blown 386 Members Classifieds - Non-Automotive 3 02-27-2012 05:00 PM
Amp in gm mtx subs not working tcarro2001 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 11-24-2010 04:37 PM
Problem with GM MTX subs tcarro2001 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 11-09-2010 11:13 PM
Shopping for tight, accurate subs...help? MikeBing Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 24 01-05-2010 12:28 PM
