![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
Blown cars that have removed the cats, any boost drop?
I`ve read where a lot of people are worried about cats coming apart on boosted cars, I know a few mustang guys that have had this happen, could be the tune whatever, regardless of the reason do we know if there is a boost drop by removing the high flow cats to an offroad pipe?
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
None on mine.
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
so boost stayed the same, thats cool, thought it might drop a little, but then again, our high flow cats are pretty free flowing these days.
![]() ![]() Drives: 2SS/RS LS3 RJT Join Date: Jun 2009
GMRulz,
I was wondering the same thing. I haven't had any issues with mine so far. |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It may drop a pound but probably not even that. I had headers and catless midpipe installed and tuned on my vette recently and it only lost a pound of boost. I'm perfectly happy with that cause it just means its making the power more efficiently.
#6 |
![]() ![]() Drives: Blown G8 GT Join Date: Apr 2010
I need to remove mine. I think it's the cause of my having too much boost(13lbs) on a 3.9 pulley
#7 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Mine dropped 1.5 pound
![]() ![]() 665. rwhp /562. rwtq @ 9.3 psi |
#8 |
Hugger Orange
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80 Join Date: May 2010
Mine dropped one pound and gained 20RWHP.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Mine melted awhile back. No change in boost level though with straight pipes.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
#10 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
#11 | |
![]() ![]() Are you seeing a boost drop when removing the cats or your setups Ted?
#12 |
Did you have high flow cats or factory cats? If aftermarket what brand?
#13 |
GMRULZ,
It seems like a lot of folks are getting spooled up over this like the gear issues. That turned out to be related a lot of times to improper install. I think this cat issue may be along the same line. How are ADM, Jannetty, and Lingenfelter holding up? A tune that's too rich will foul the cats over time won't it? |
#14 | |
Yeah, if the cats are working over time they may go bad, I`m not really that worried about mine, of course an ounce of prevention might be a good thing, moreso I was deciding if I should remove them and drop a pulley size trying to calculate if there was any boost drop form the cat delete and if so how much. The other thread i have going is about 10lbs boost not meth no knock, I guess I could have merged them but they get more specific replies when seperate.
