Old 05-13-2012, 11:47 AM   #1
xtreme industries
Drives: 2010 Camaro 2lt RS
help with rasp
i just installed the obx long tubes, i have the pypes cat back dual m80 exhaust. now it sounds like crap. what is the best way to remove the rasp without loss in performance.
muffler shop recomended twister race mufflers in the rear.
xtreme industries is offline   Reply With Quote
Old 05-13-2012, 11:51 AM   #2
montreal2010yellow
montreal2010yellow's Avatar
Do It Yourself J pipes....
Old 05-13-2012, 11:53 AM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Might want to look into a magnaflow x-pipe
kjkjr27 is offline   Reply With Quote
Old 05-13-2012, 12:29 PM   #4
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Magnaflow resonated x pipe. Proven to work
Old 05-13-2012, 12:43 PM   #5
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Add a magnaflow resonator X-Pipe. Might get more power too. I did.
shrinkdoc is offline   Reply With Quote
Old 05-13-2012, 04:11 PM   #6
bmorecam
either J-pipes or perforated X pipe. Welcome to the rasp land LOL!
Old 05-13-2012, 04:48 PM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Will J-pipes help with rasp? Most have done it for drone...
scrming is offline   Reply With Quote
Old 05-13-2012, 04:49 PM   #8
bklyn_tap
bklyn_tap's Avatar
Drives: 2011 camaro LS
I was thinking of getting the same headers. I already have a mrt v2 with a bbk xpipe. My bbk xpipe will help prevent the same rasp right?
bklyn_tap is offline   Reply With Quote
Old 05-13-2012, 05:19 PM   #9
KMPrenger
KMPrenger's Avatar
Resonated X pipe for rasp....J pipes for drone.
Old 05-13-2012, 05:49 PM   #10
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I don't think the bbk xpipe is resonated so I don't believe it will help. The res x from magnaflow is listed as muffler on their site. It really an xpipe with a muffler around it which is why it works.
OOLIE is offline   Reply With Quote
Old 05-13-2012, 05:52 PM   #11
xtreme industries
no room for magnaflo because my mufflers are centrally located. i am looking to add something to the rear area where the old mufflers used to be.
there is an X pipe in my exhaust but its not a resonted x pipe.
Old 05-13-2012, 05:55 PM   #12
xtreme industries
does anyone have a model number for the magnaflo and some pictures of where it is located on the car?
Old 05-13-2012, 05:55 PM   #13
KMPrenger
KMPrenger's Avatar
Yes...go for the magnaflow resonated X pipe (muffler) part # 11386 and have a shop replace the current X in your setup with it if you can. It will help with rasp and loudness for sure
Old 05-13-2012, 06:00 PM   #14
KMPrenger
KMPrenger's Avatar
Is this what it is?
I can see how getting a magnaflow resonated X in there could be tight. Looks like two resonators or small round mufflers after that.
You could look up the dimensions of the magnaflow resonated X with the part number I provided above and see if that would fit. Otherwise I'd suggest adding a couple resonators near the end if not a pair of full mufflers....but then you are completely changing the system and you will need to decide for yourself what mufflers to go with.
