![]() Drives: 2013 2SS/RS dusk edition . Join Date: Sep 2011
25mm Mace Insulator instal questions
So i ordered the 25mm insulator but im confused as to how the install goes. Do the bolts have to be tightened to a certain tq? how easy is it overall? too hard for someone who hasnt worked on engines much??
HT5 EastSide
dude, idk but I was about to ask the same thing. I personally dont have a tq wrench so what do I do?
![]() Drives: LS/LLT Join Date: May 2012
I'm sure others will chime in soon but I'm pretty sure the bolts are supposed to be 18lbs of torque. Any more than that and you might cause some damage.
Here's a link to the Plenum Spacer thread http://www.camaro5.com/forums/showthread.php?t=216432 and the Insulator thread http://www.camaro5.com/forums/showthread.php?t=188097 All of the answers should be there...or closeby I have all three (intake manifold, plenum spacer, insulator) on order and plan on doing a install video/pics and tutorial when they come in |
![]() Drives: LLT Machine Join Date: Nov 2011
We have some preliminary instructions for installing these spacers on an LLT, which can be downloaded from the link below
http://www.mediafire.com/?96jmauez33xrr8b Given that you guys are installing these on a Camaro's I would treat this as more of a guide as it will be easier to install these on a Camaro give the higher bonnet/firewall space Also make sure you use sealant on both sides, which isn't clear on the instructions Hope this helps, Kindest Regards, Steve |
| Tags |
| install, insulator, mace |
