Old 05-26-2012, 01:26 PM   #1
Camaro Fred
2012 ZL1 VIN 150
Drives: 1973 RS LT Camaro 4 Speed
Lightbulb ZL1 Front License Plate "No drilling" Installation
Driving a ZL1 (ticket magnet) in CA where front license plates are required, I decided to find a way to mount my front plate without any drilling or loss of front clearance. Brackets from underneath reduce clearance, so I started looking behind the grille at mount points. To my surprise, I found two bracket mounts symetrically located ~ 4.5" from the car centerline on the bottom of the radiator tank. A small amount of trimming on the plastic air diverter (found below and in front of the radiator) is required. All of the materials used came from Home Depot.
To access the bottom of the radiator, you need to remove the underbelly pan (you will need to do this for your oil change anyway). I took some pictures and annotated them to show how easy it was. If you have questions PM me.
Camaro Fred is offline   Reply With Quote
Old 05-26-2012, 01:48 PM   #2
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Nice job. I like it!
Happy_Dan is offline   Reply With Quote
Old 05-26-2012, 02:06 PM   #3
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
that is quite clever.
SnoopyAce7 is offline   Reply With Quote
Old 05-26-2012, 02:53 PM   #4
OC ZL1
OC ZL1's Avatar
Drives: 2013 ZL1 AGM
Excellent job, better location than the factory mount. I will do something similar whenI get my car. Thanks so much for sharing your details with your fabrication and installation.
Enjoy your ZL1!
OC ZL1 is offline   Reply With Quote
Old 05-26-2012, 03:08 PM   #5
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
+1
FINALLYSATISFIED is offline   Reply With Quote
Old 05-26-2012, 10:39 PM   #6
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Now that's some fine engineering there, Lou.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 05-26-2012, 10:55 PM   #7
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Great Job, works for me !
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 05-27-2012, 10:09 AM   #8
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Excellent work. Subscribed.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 05-27-2012, 03:46 PM   #9
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
Excellent job Lou!
shockandawe is offline   Reply With Quote
Old 05-27-2012, 04:48 PM   #10
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Originally Posted by shockandawe View Post
Excellent job Lou!
Hahaha...I don't think his name is Lou...I was channeling Police Chief Wiggum from the Simpsons.
Old 05-27-2012, 05:57 PM   #11
Camaro Fred
2012 ZL1 VIN 150
For those who are considering building a front license plate bracket of your own, I have listed the links to the parts you will need at Home Depot. It will take about 3 hours of your time (leisurely pace) to complete this job.
Here is the aluminum - 1 48" piece reqd ($5.72)
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Here are the corner brackets. One package (contains two pieces) reqd. ($4.97). Note - throw out the wood screws in this package
http://www.homedepot.com/webapp/wcs/...17&R=202034217
You will also need four 1/4" x 1/2" stove bolts and four 1/4"-20 nylon lock hex nuts. These are used to mount the brackets to the aluminum stock and and brackets to the pre-existing radiator mounts. (~$2.00)
You could paint the bracket with any type of paint, however I used a rubberized coating to reduce any vibration between the grille and the aluminum bracket. ($5.98). Wipe the aluminum and corner brackets down with a solvent before painting.
http://www.homedepot.com/webapp/wcs/...10&R=100131010
For the license plate back plate, I ordered this on e-bay motors. You can get them lots of places. ($12.95)
http://www.ebay.com/itm/Universal-Mo...c1507f&vxp=mtr
Total cost = $31.62 + tax
Old 05-27-2012, 07:16 PM   #12
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Fred, what did you use to notch the aluminum in the backet?
Old 05-27-2012, 08:27 PM   #13
Camaro Fred
2012 ZL1 VIN 150
I used my Dremel and a metal grinding stone. You don't need much of a notch, just enough to clear the bottom section of the grille. The notches face down when the piece is installed on the car.
Another note: The radiator mount already has the nuts in it, you do not need to provide them. All you need is 1/4" x 1/2" long bolts to go in the nuts in the mount.
Old 05-27-2012, 09:48 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Wow. That's a much cleaner installation than mine!
Looks good!
front license plate, mounts
