Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 06-02-2012, 05:57 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
tremec 6 speed/pedal/act twin disc
replacing my tremec manual 6speed with 4l80...tranny-pedal assy-gto clutch reservoir-act twin disc clutch -slave cylinder..i believe everything is here to install a 6 speed...looking for some offers , tranny is located in florida...approx 3-4k miles on clutch and 8000 miles on tranny
mikepage0007 is offline   Reply With Quote
Old 06-02-2012, 06:13 PM   #2
rocket69GTP
Drives: G8
Oh dear god, why oh why did you post this. Another Tremec swap into a G8 would be sweet!!!
rocket69GTP is offline   Reply With Quote
Old 06-02-2012, 06:58 PM   #3
mikepage0007
Drives: 2010 camaro
dshaft is a chromoly and is def stronger then any other dshaft available..but would need to be shortened to fit ...it was built with a gforce 9inch...i do have the original dshaft
Old 06-02-2012, 09:49 PM   #4
SLOWG8
Drives: g8
how much you thinking for the transmission?
SLOWG8 is offline   Reply With Quote
Old 06-03-2012, 01:41 AM   #5
mikepage0007
Drives: 2010 camaro
open for offers, tranny is only worth what people are willing to pay...have the word out to a couple other people i know, also a couple gto friends...gonna bump this thread for a week and see what pops up...throw out your best offer, i wont be offended..hopefully by next weekend , i will sell it to someone..
Old 06-03-2012, 04:16 PM   #6
Posidon42
Drives: 08 G8 GT
For those considering the G8 conversion, you will need a new bell housing and driveshaft as well as some other small parts. My conversion will start next week.
Bump for OP as we need more of these on the road.
Posidon42 is offline   Reply With Quote
Old 06-03-2012, 04:23 PM   #7
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Why would you need a new bell housing?
JLE58 is offline   Reply With Quote
Old 06-03-2012, 04:37 PM   #8
mikepage0007
Drives: 2010 camaro
could be wrong, but i did not think that the bellhousing could be romved from a tremec...since there is no blowproof bellhousing available form it as it cannot be removed..and replaced for one..that was why guys were running autu tranny blankets on them and tech was letting them pass..i really never looked , but now you peak my curiousity
Old 06-03-2012, 04:54 PM   #9
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Bellhousing can be removed... just removed mine last night.. Bolts on from the inside of the housing around the slave...
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 06-03-2012, 10:54 PM   #10
mikepage0007
Drives: 2010 camaro
thanks for the input, i guess they just don,t make a blowproof bellhousing for the tremec yet, but still can,t figure out why you would have to cahnge bellhousing for a gto swap...it would mount up to a ls1 thru ls3 or l99 with no issues...
Old 06-04-2012, 09:10 AM   #11
JLE58
Yeah mike they make a aftermarket bellhousing. I also dont understand why you would need to change the bellhousing for a swap.
Old 06-04-2012, 01:32 PM   #12
Third-Gen
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060
only difference between the t56 and tr6060 bolting up is the input shaft length. the t56 is longer, and needs the smaller roller bearing type pilot bearing, the tr6060 is shorter, and uses the larger ball style pilot bearing. the small roller bearing fits into the smaller hole deeper in the rear flange. just did a swap in a gto, left the t56, but put an ls3 behind it. had issues bolting the trans up, realized it was bottoming out on the pilot bearing. one trip to autozone and it was all good! how much are you asking for this setup? I am on the market for a trans/clutch setup.
the ls2 still uses the older style roller bearing (gto, G8)
T56 from an LT1 and LS1, LT1 is on the left.
TR6060 pilot bearing.
Third-Gen is offline   Reply With Quote
Old 06-04-2012, 01:37 PM   #13
Third-Gen
Olson Kustom Works
just for reference, found a pic of the 2 bearing locations:
Old 06-04-2012, 06:43 PM   #14
mikepage0007
Drives: 2010 camaro
thats what i thought, it had to be a shaft length issue..send me pm,s on price you are wanting to pay, shipping is the biggest issue as this is a costly shipping part..
