Old 06-11-2012, 06:23 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
DIY Oil change tips?
Anyone got good tips & tools for changing the oil on our SS's?
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 06-11-2012, 08:03 PM   #2
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
Everything is pretty easy. Make sure you have an oil drain pan that can hande 8 quarts or you will have a mess. Also, the filter is a little hard to loosen by hand. I recommend a oil filter socket that you can turn with a ratchet wrench. The oval ones that are universal are a pita on our filters.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 06-12-2012, 12:36 AM   #3
Avalnch
Avalnch's Avatar
Thanks, Wild Bill, that's just what I wanted to hear. So, I guess not much different than my old Gen3 5.0 H.O.
Old 06-12-2012, 12:56 AM   #4
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
I have plastic ramps. They work great for lifting the front end. Bottom lip of front facia drags slightly. If front end is lowered use boards in front of ramps for clearance. Other than that its pretty easy.
CRUZN-SS VIA tapatalk
CruznSS is offline   Reply With Quote
Old 06-12-2012, 08:31 AM   #5
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
replace the stock plug with the magnetic type.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 06-12-2012, 03:53 PM   #6
Avalnch
Avalnch's Avatar
Thanks, does GM make one? Which one do you have and where'd you get it?
Old 06-12-2012, 05:04 PM   #7
y2k king
y2k king's Avatar
here's a place.
http://www.camaro5.com/forums/showthread.php?t=60055
10/28/2010 got it
Old 06-12-2012, 08:58 PM   #8
Kinetic Kev HWSE 2013
Kinetic Kev HWSE 2013's Avatar
Drives: 2013 Hot Wheels Special Edition
Dont spill the oil
Kinetic Kev HWSE 2013 is offline   Reply With Quote
Old 06-13-2012, 12:03 AM   #9
The Sandman
Flying Low & Raining 3's
The Sandman's Avatar
Drives: 2012 Camaro SS 45th Ann. Edition
As mentioned, the oval filter wrenches can be difficult. But there is a smaller size oval filter wrench which actually works ok.
I went with a Dimple magnet plug. It’s a bit longer, reported to have the strongest magnet, and more closely resembles the stock plug in length. However, I think they all are better than the stock.
Prior post of a step by step for the V8:
http://www.camaro5.com/forums/showthread.php?t=53422
The drain plug and oil filter are located somewhat close to each other under the car on a V8. It's my understanding that the V6 is different.
If you've warmed up the car, with 8 quarts the oil will initially shoot out of the vehicle a good distance so plan to place your collection pan a distance away from the plug initially.
If you torque the oil plug it takes 18 lbs. I've always cranked it on by socket or wrench good and tight.
The Sandman is offline   Reply With Quote
Old 06-13-2012, 05:30 PM   #10
Bobaloo
Member "O'l Farts"
Drives: 2012 SS Coupe/Automatic/Sunroof
I sent my "Gold Plug" magnetic oil plug back for a $18.00 refund. Although it was magnetic I don't like the fact that it uses an aluminum thin washer and the plug head wasn't nearly as big as the OEM which BTW has a nice rubber insert washer built in the plug. Our oil is full synthetic and has a good tendancy to leak or seep with a poor seal. I'm sticking with the OEM oil plug. Even though I could have used some permatex thread sealer I just don't trust that thin washer.
Bobaloo is offline   Reply With Quote
Old 07-01-2012, 02:17 AM   #11
jag107
jag107's Avatar
Drives: 2010 2SS/RS IOM M6
Check the tightness on your filter after replacing, before you lower the car. Mine spun loose after my first change (Napa 7060, hand tightened), just enough to leave about 6 oz. on the floor of my garage about 400 miles after the change was done. Lucky it didn't spin off any more while I was on the road!
Placed order: 02.25.2010
Took delivery: 04.06.2010
Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links
jag107 is offline   Reply With Quote
Old 07-01-2012, 03:02 PM   #12
cpoboats
cpoboats's Avatar
Drives: 2011 SS/RS gun metal gray ragtop
Gold plug/oil filter
My 2 cents; the thin washer on the gold plug is meant to be replaced each time as it crushes went torched. As for the loose filter, 2 birds, one stone; if you get the K&N filter it has a nut 1" on the bottom to loosen and a small hole to safety wire it so it can't back out. Just say'n....
cpoboats is offline   Reply With Quote
Old 07-01-2012, 11:58 PM   #13
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
I helped my friend do a oil change on his 2011 Camaro SS
and he uses Mobil 1 5W30 synthetic motor oil with Mobil 1
oil filters and we didn't have any problems getting the oil filter on or off.
Just make sure you get the oil filter on tight enough and you
will be fine.
Blueovalman is offline   Reply With Quote
