Old 06-21-2012, 06:08 PM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
Exclamation Shop did not install my C5R chain and LS7 dampner during LS3 conversion
Just received a phonecall from the shop. My car is ready.
They installed a LS3 conversion, Trunion upgrade, new cam, new heads, dual springs, hardened pushrods, ...
I am really happy with their work and this shop got *great reputation over here.
They told me they did not install my C5R chain and the LS7 dampner because of the following reasons:
- My car is still brand new (2'500 miles)
- they never had any problems with the stock chain and dampner
- If you open the chain "housing" and reuse all the stock gaskets it won't be as well sealed as before
- it is very extensive/time consuming because the oilpan has to be opened and the oilpump has to be removed
Do this statements make sense to you guys?
mike.nite is offline   Reply With Quote
Old 06-21-2012, 06:19 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
they didnt want to open up the oil pan obviously. you have to lift the engine way up to get it to drop far enough to get the pump off. Did they say they were going to do it prior to "digging into it"? You should have been charged more to pull the oil pan to change the chain, were you? its damned near impossible to change the pump with the pan on. my oil pan was about 1/4 from the bolt head for the oil pump. when i seen that, i pulled the engine. there is no way it would come off without dropping the pan, and with all the crossmenbers on these cars, it is not a fun job.
but if you paid for it, they should have done it, or gave you the choice when they figured this out.
nighttowl is offline   Reply With Quote
Old 06-21-2012, 06:21 PM   #3
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
How did they install the cam without removing the "chain housing" which I assume they meant timing cover? If you provided the parts and asked for them to install them, they should have installed them. When you're that far into it, it's not much more work to do the swap. I changed to the C5R timing chain and dampner when I did my cam.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 06-21-2012, 06:22 PM   #4
nighttowl
nighttowl's Avatar
by opening the housing, they mean grinding out the casting. a double roller chain will not physically fit without modification.
Old 06-21-2012, 06:23 PM   #5
yotaman96
yotaman96's Avatar
The pan only has to be slightly lowered to separate the pump and pickup tube.
2002 Trans Am
Old 06-21-2012, 06:24 PM   #6
yotaman96
yotaman96's Avatar
The C5R chain is not a double roller.
2002 Trans Am
Old 06-21-2012, 06:31 PM   #7
nighttowl
nighttowl's Avatar
then there is no reason not to install it. my guess would be that they forgot they had parts to install, and remembered after it was too late.
that sucks.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
Old 06-21-2012, 06:44 PM   #8
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
Sounds like they flat rated the job. Probably pulled the timing cover, saw that getting the chain and oil pump out is a little more work and just decided to put it back together and give you a line of crap.
MRGOODWRENCH3 is offline   Reply With Quote
Old 06-21-2012, 06:46 PM   #9
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
that sucks.
This
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 06-21-2012, 07:18 PM   #10
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Don't worry it will be fine. I asked all the chain and tensioner questions when i did mine and every shop i talked to said the stock parts will hold up, No problems so far.
tkrupinski is offline   Reply With Quote
Old 06-21-2012, 07:26 PM   #11
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
More likely it will be fine, damper is main suspect others have ran it in success. Main thing is running a 3 bolt cam and gear.
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 06-21-2012, 07:43 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
no worries if they thought it would be a problem they wouldnt let ur car go if they are a good shop. i know a few cars in my area that done the same and have had no problems yet
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 06-21-2012, 07:48 PM   #13
Ivan @ Southwest Speed
Did they charge you for it? If not, eh....but it would be nice to have that choice.
If so, Id say that they are lazy, forgot, or are just lazy. Oh did I say that twice?
FWIW.
Ivan
Old 06-21-2012, 08:56 PM   #14
Birm
Birm's Avatar
Drives: Florida Speed & Power
You will be fine. Many cars run without the dampner including myself.
Birm is offline   Reply With Quote
