Old 06-29-2012, 01:07 PM   #1
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
oil filter housing stuck
Anyone have any tips for breaking lose the oil filter cap on the v6 camaro? I've tried a break bar, rubber mallet on the wratchet. I've tried everything and this thing just wont break loose. My cousin put it on there wayyyy too tight last time I guess. last time I trust him with anything...
Iomcamaro is offline   Reply With Quote
Old 06-29-2012, 01:27 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Wow it must be really thight if you cannot get it off with a breaker bar. Maybe use an impact wrench, allthough I might be scard to go that route.
And can your cousin read, it stats how much to torque it right on it. He probably also forgot to oil the ring so now it's fused.
FSP tuned: 377/389
Old 06-29-2012, 01:36 PM   #3
Iomcamaro
Iomcamaro's Avatar
no the oil ring is on there. I put that on there. I also oiled the ring so I know it's not that. He just tightened it while I put the oil plug back in. which came out with no problems...
Old 06-29-2012, 02:37 PM   #4
jordan 572
jordan 572's Avatar
Drives: none
Are the v6's an element style or an actual metal filter?
jordan 572 is offline   Reply With Quote
Old 06-29-2012, 02:57 PM   #5
Iomcamaro
Iomcamaro's Avatar
There is a canister on the side of the engine that you take the cap off to get the filter.
Old 07-16-2012, 10:30 AM   #6
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
IrocJack is offline   Reply With Quote
Old 07-16-2012, 12:24 PM   #7
montreal2010yellow
montreal2010yellow's Avatar
I really don't have a solution for you but last time I had the oil change, the cap was very, very hard to unlock. I read somewhere that the cap has to be torqued at 25 Nm.
Old 07-16-2012, 12:34 PM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
I believe it's 18 but not like there should be much question to it, it says it right on the cap.
FSP tuned: 377/389
Old 07-16-2012, 03:12 PM   #9
IrocJack
IrocJack's Avatar
Lefty Lucy, Righty Tighty- If you are using a breaker bar on that little cap and cannot loosen it you have a problem.
