Old 06-30-2012, 11:40 AM   #1
TriGun
TriGun's Avatar
Drives: Camaro 2SS/RS Ice Silver
ZL1 fuel pump question
Does the ZL1 fuel pump require any kind of rewiring to get it to work on 2010 Camaro SS like the LPE twin fuel pump ?
Does any one have installation guide for ZL1 fuel pump ?
Will my current MSD BAP work with ZL1 fuel pump ?
TriGun is offline   Reply With Quote
Old 06-30-2012, 11:45 AM   #2
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Plugs right in like the stock pump, nothing special needed and works with your BAP, been running mine for several months now.
swiftkart is offline   Reply With Quote
Old 06-30-2012, 12:39 PM   #3
Supermaro585HP
Drives: 2011 Camaro SS RS
Just got mine this week.. Looks like a pain in the ass to put in. I was quoted 6 hours to put in. I need mine becauase I'm putting a smaller puller in for my supercharger.
Supermaro585HP is offline   Reply With Quote
Old 06-30-2012, 01:19 PM   #4
NC-V
NC-V's Avatar
Drives: cts-v
ZL1 pump is a piece of cake to install vs. the LPE twin (nothing against the LPE twin, awesome setup just more work) It is basically plug and play, no wiring necessary and it will work with the BAP as said above.
NC-V is offline   Reply With Quote
Old 06-30-2012, 01:57 PM   #5
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
Once you have access to it is easy as long as you have the locking ring tool also.
I am running with BAP too.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 06-30-2012, 02:13 PM   #6
NC-V
NC-V's Avatar
Drives: cts-v
Yes the lock ring tool makes it much easier, can be done without it with the help of a third or fourth hand.
Old 06-30-2012, 02:29 PM   #7
Supermaro585HP
Ok how long did it take to put in????
Old 06-30-2012, 02:44 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Also, how much more capacity is the ZL1 pump over stock?
I still have the stock pump with a BAP.
Old 06-30-2012, 03:38 PM   #9
NC-V
NC-V's Avatar
Drives: cts-v
An experienced tech with lift and tools can do it in under a half day, just drop rear subframe, drop tank swap pump and re-assemble. At home on tall jack stands I would plan a day for it just to be safe. As for the limits, I'm not sure/haven't pushed one yet. Have run in the 550 rwhp (no BAP) range without pressure drop, but haven't used it in anything more powerful than that yet (have always used the LPE twin on bigger stuff)
Old 07-01-2012, 02:24 AM   #10
ChriSS84
Drives: 2SS
The rating is 600bhp, so it would be an upgrade over the stock SS fuel pump.
ChriSS84 is offline   Reply With Quote
Old 07-01-2012, 06:56 AM   #11
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
Pq some run the zl1 pump with the bap set at low voltage
I may do this as well at some point although right now I don't think I need it
1969to2010 is offline   Reply With Quote
Old 07-01-2012, 08:51 AM   #12
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
better off selling your BAP and getting the ADM fuel control module.
Old 07-02-2012, 04:23 AM   #13
2010SSRSM6
2010SSRSM6's Avatar
I'll let you know tomorrow how it does on a LS3 w/IW 10% OD 8 rib, Maggie w/3.6" pulley, cam, FIC 850 injectors and LTs. I'm not expecting it to run out of fuel and it will be well over 700bhp. Factory pump was fine @ 630bhp.
Old 07-02-2012, 12:50 PM   #14
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
In a garage on jack stands, 2 people = 4.5 hours
sscamaro is offline   Reply With Quote
