Old 07-14-2012, 04:46 AM   #1
Sportieeeee
Sportieeeee's Avatar
Drives: 2011 LT Camaro RS
Need a little help "Door Handles"
[B]Anyone know the first step in removing the door handles? Not sure theres a post on here explaining how, i looked around but no luck. I want to install a small red light behind the door handle for some lighting effect. Thanks
Sportieeeee is offline   Reply With Quote
Old 07-14-2012, 10:10 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
This DIY is from overhaulengines (lupe ) he did this a long time ago, good luck. http://www.camaro5.com/forums/showthread.php?t=116016
Old 07-14-2012, 10:48 AM   #3
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
Yea it's easy don't do what I did I had to end up taking the door of turning it upside down and shaking it to get the screw out. Open the door you'll see a black circle take it out and there will be a star screw in there pull on the handle and hold it and turn the screw after afew turn the handle will be stuck in the out position Now grab the little piece of the handle and pull lightly and keep turning the screw until it slips out once it does don't turn the screw anymore or it will fall out. After that comes off pull the door handle and slide to the outside of the door and the latch will come undone the pull towards you and wiggle the other in out. To put back in do all this backwards. Hope this helped Im on an iPad so I can't post pics or I would
Cliffjumper is offline   Reply With Quote
Old 07-14-2012, 10:51 AM   #4
Cliffjumper
I wouldn't suggest doing it the way in that tutorial its more work then it should be That plastic should not be popped off while it's still on the car like that. You could break the clips. Plus if you do it the way I said you don't have to pull that metal piece on the inside of the door cause it's stuck in that position already
Old 07-14-2012, 11:16 AM   #5
2012_1LT/RS
Drives: 2012 Camaro 1LT/RS
i think he is talking about the inside door handles like the new Chargers are right? or are you talking about the outside?
2012_1LT/RS is offline   Reply With Quote
Old 07-14-2012, 11:24 AM   #6
Cliffjumper
The only lighting mod for door handles I've seen are for outside inside would be impossible since door handles are Chrome and solid all the way through
Old 07-14-2012, 11:26 AM   #7
2012_1LT/RS
But you could insert a small LED inside on the door panel that acts like a courtesy light inside just behind grab handle
Old 07-14-2012, 11:28 AM   #8
Cliffjumper
That would be cool. Kinda like abl
Old 07-14-2012, 11:29 AM   #9
Cliffjumper
I wrapped that plastic insert in white leather to offset it withe the red in my door
Old 07-14-2012, 11:30 AM   #10
2012_1LT/RS
exactly i looked the other day and there is just enough room for a small single LED inside the door handle and you would never notice its there
Old 07-14-2012, 11:31 AM   #11
Cliffjumper
I feel another mod to add to my list lol
Old 07-14-2012, 11:36 AM   #12
2012_1LT/RS
i have been thinking about it nervous to drill in new car....but if you ever get to look at a 2012 Charger you will see what i mean
Old 07-14-2012, 11:40 AM   #13
Cliffjumper
I actually test drove one the molar edition and didn't notice it
Old 07-14-2012, 11:40 AM   #14
Cliffjumper
Mopar
