Old 07-16-2012, 10:21 PM   #1
Neto1978
Drives: 2011 camaro ss victory red
Factory engine oil 5w30 semi-synthetic?
The engine oil filled at factory is semi or full synthetic?
Tks
Neto1978 is offline   Reply With Quote
Old 07-16-2012, 10:33 PM   #2
5cents
Dave
5cents's Avatar
Drives: 2011 Camaro SS - Black/CGM Stripes
I'm not positive if it comes in all the Camaro models, but the SS's come with Mobil 1.
5cents is offline   Reply With Quote
Old 07-16-2012, 10:41 PM   #3
mulletman
Drives: 2017 Camaro SS
Full synthetic factory fill of Mobil 1 on the SS.
mulletman is offline   Reply With Quote
Old 07-16-2012, 10:41 PM   #4
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Fully synthetic
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 07-16-2012, 10:44 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
Mobil 1 in our cars if it is that is not full syn. Also the oil is some Dexos GM brand stuff a semi syn grade. Bottom line that GM oil will never set it's rear end in my oil pan again.
Old 07-16-2012, 10:58 PM   #6
themoneypit
Drives: 2012 45th convertible ss ls3
my 2010 ss was mobil 1 factory filled, but now the ss comes with the dexos semi synthetic. that was drained at 1k miles on mine and use mobil 1 5/30 from here on out.
themoneypit is offline   Reply With Quote
Old 07-16-2012, 11:01 PM   #7
mulletman
Thank you for the clarification. I was not aware of the change.
Old 07-17-2012, 12:10 AM   #8
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Tks
Neto....running the build sheet on your car again,the build date is 10/12/2010 which was before mine (02/01/11) and mine came with MOBIL1,so yours would have had MOBIL1 as well. It will also say "MOBIL1" on the oil filler cap.
I believe very late build '11 cars came with Dexos,and all 2012's call for Dexos.
Keep in mind your Silverado also calls for Dexos.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 07-17-2012, 12:14 AM   #9
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
I never break in engines with synthetic oil, GM did the right thing. I change oil early on new engines, no more than 500 miles.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-17-2012, 12:17 AM   #10
MS3DALE
MS3DALE's Avatar
True,you have to run MOBIL1 "Extended Performance" for a group IV true full synthetic oil.
Also,GM brand Dexos oil is made by Mobil.
Old 07-17-2012, 12:18 AM   #11
MS3DALE
MS3DALE's Avatar
Same here,I've always done my first oil/filter change between 500-1,000 miles.
Old 07-08-2013, 10:10 PM   #12
RS Speedriver
RS Speedriver's Avatar
Drives: 2018 camaro 1ss 1LE
so my car has close to 30k and oil change is coming up. should I go with factory again and use the dexos or change to mobil 1 and would this void any warrenty?
RS Speedriver is offline   Reply With Quote
Old 07-08-2013, 10:36 PM   #13
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
mobil 1 extended performance is dexos....
Glen e is offline   Reply With Quote
Old 07-09-2013, 12:41 AM   #14
RS Speedriver
o okay I give it a try thx guys
