Old 05-24-2009, 10:54 AM   #1
chevyridinghigh
The Bowtie Is Back
chevyridinghigh's Avatar
Drives: 2010 Silver Camaro SS/RS -Blk Int.
Camaro Winter Driving
Okay, for those of you that plan to drive the hell out of this car and put on more miles than a 100 mile per year weekend car, what do you plan on doing during the winter when it snows? I've never had a rear wheel drive car, being that I'm 24 and have driven a honda civic for about 9 years. Chains on the tires???
2SS RS SIM M6 with Polish Silver wheels
chevyridinghigh is offline   Reply With Quote
Old 05-24-2009, 11:02 AM   #2
dirkmalone
Drives: Dodge Challenger
You can't go around with chains on your tires. They will rip up your tires and the roads. You can only use tire chains in certain places (up steep hills, etc.) and then they generally are required to be removed. You should get a good set of dedicated winter tires (and rims). It makes a big difference. Easy on the throttle, take your time and the rear-wheel drive will be fine. I'm from Edmonton, Canada and my first car was a rear-wheel drive Cutlass...no problem if you know how to handle it. You can't use tire-chains on the roads here, or studs.
dirkmalone is offline   Reply With Quote
Old 05-24-2009, 11:08 AM   #3
Vash
Drives: 00 Blazer
Hum just remember it's not FWD it's RWD. Do some google action on it and look at the various RWD forums for winter tips. There are probably threads on it buried in this forum.
Old 05-24-2009, 11:09 AM   #4
Epitaph
Custom User Title
Drives: Fast
I'm going to install something in the garage in a few years that will rinse off the entire car (during the winter) every time it snows & after.
I don't know what happened to the rest of my post?
& Chains only when necessary...Winter Tires & Rims as said before
Epitaph is offline   Reply With Quote
Old 05-24-2009, 11:26 AM   #5
rays
V6 - It just isn't normal
rays's Avatar
Drives: 2010 2LT M6, F250 7.3L Diesel
I'll be driving my 4x4 pickup truck. I'm not watching this one rust out from road salt. Whatever they are using on Highways around here these days is much worse than it was in the past.
2LT RS M6 RJT Black leather
4/29/2009 Ordered
6/24 6000 Delivered
rays is offline   Reply With Quote
Old 05-24-2009, 12:59 PM   #6
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
The big difference in the snow between RWD and FWD is that if you start spinning RWD's tires while moving (or sometimes from a stop), it will get sideways on you. If you get the V6 auto then you'll have a little bit of leeway with the open differential, but with the limited slip you'll get sideways very easily. Secondarily, if it starts understeering there's nothing you can do; with FWD you could apply some power and maybe do what I call a FWD powerslide.
The rest is pretty much the same. FWD does NOT avoid getting stuck any better (given appropriate weight distribution, which the Camaro definitely has). You may want narrower tires, you'll definitely want winter tires, and you may want sand-embedded (do they still make those?) or studded tires.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-24-2009, 01:18 PM   #7
surferbarney
surferbarney's Avatar
Drives: 2010 Camaro, 1999 Mustang
I won't be driving my camaro in either the rain or snow but I do currently have a mustang and that will be my daily driver which I will have to drive in bad weather. The mustang is horrible in the snow, and likes to fishtail if you aren't careful, but as long as you know what you are doing and don't try to floor it you'll be alright. The best thing to do is get some good winter tires and just take it easy on the gas in the bad weather. Might be a good idea to go to a big empty parking lot in the snow to just drive around, make it fishtail, and learn how to handle it. I did that when I first got my license and it helped a lot.
2010 Camaro 2SS RS
IOM exterior, IO interior
Black Rally Stripes (painted aftermarket)
GFX Package
Pre-Ordered 1/19/09
2000 4/9/09
3000 4/24/09
3300 5/4/09
3400 5/9/09
3800 5/15/09
Delivered 6/2/09!!!!!
VIN 2G1FT1EWXA9110199
surferbarney is offline   Reply With Quote
Old 05-24-2009, 01:25 PM   #8
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
I am parking my camaro in a storage facility in Jan and Feb and driving my GMC Sonoma. I put about 100 lbs on weight in my truck bed next to the wheel wells.
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 05-24-2009, 01:43 PM   #9
Vash
Drives: 00 Blazer
Make sure you get uninsured / underinsured too.
The Stabilitrak system has 3 components and 4 modes.
Mode one is what you want in ice. This is ABS on traction control on and roll control on.
Old 05-24-2009, 01:53 PM   #10
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
When my car comes in, I'm gonna have the dealer test fit some stock wheels from an impala or other Chevy vehicle to see what will go on the hub (LT with RS 20" wheels).
Hopefully, something will fit and I'll buy these wheels too. Then shop for snow tires in November. So I'm delaying gratification for CAI and catback exhaust for the practical snow tires/wheels.
Plus, the price for the mods will come down after more vendors get in the game.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 05-24-2009, 01:55 PM   #11
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Drives: Not a Camaro
i live in texas. it never snows and hardly rains. so i get to drive it year round. lucky me. but for spring rains when it floods i will be driving my jacked up 84 chevy. =]]
bossbunny is offline   Reply With Quote
Old 05-24-2009, 02:00 PM   #12
Miketebo22
Iceman
Miketebo22's Avatar
Drives: SOLD #20,908 SS waiting for ZL1
Send a message via MSN to Miketebo22
Chains are only for heavy, accumulated snow. Get a seperate set of wheels and tires that have winter tires on them. get some that are studded, they help a lot too. Or, just go buy a truck too! im keeping my truck and buying the camaro just because the winters we have here in South Dakota are a bit too nasty for a RWD car.
2G1FT1EW8A9120908
Miketebo22 is offline   Reply With Quote
Old 05-24-2009, 02:02 PM   #13
Buckbo
Buckbo's Avatar
Drives: 2010 Camaro
The reason I didn't order the RS package is the 20" tires are summer only. I'm getting the 19" all season rubber so I can drive in bad weather too. No auto trans for me either. I've had both an auto and a 5-speed Camaro clone (Trans Am) and the auto was terrible in winter but with the manual I never had a problem in ice or snow and that was with 50 series tires.
Buckbo is offline   Reply With Quote
Old 05-24-2009, 04:49 PM   #14
Camaro2010ss
Camaro2010ss's Avatar
Drives: '92 Ford F-150
When it snows in Texas I just stay home and play in it since it's rare, and if I had to go somewhere I'd probably just use my truck instead of my Camaro.
Camaro2010ss is offline   Reply With Quote
Some thoughts on "recent" developments on this site.... fbodfather 5th Gen Camaro SS LS LT General Discussions 258 05-08-2009 11:24 PM
Driving camaro in the winter... Th3Nigh7Stalk3r 5th Gen Camaro SS LS LT General Discussions 23 12-21-2008 11:03 PM
Automobilemag.com: 2010 Chevrolet Camaro - Q&A Scotsman 5th Gen Camaro SS LS LT General Discussions 23 10-12-2008 01:13 AM
Camaro Chat 9:30-10:00 jdpickering 5th Gen Camaro SS LS LT General Discussions 25 07-22-2008 03:11 PM
