Old 08-11-2012, 09:13 AM   #1
jkemp16
jkemp16's Avatar
Drives: 2015 Dodge Challenger SXT Plus
Switch to synthetic??
Bought my car used last year at 38k miles. I'm up to nearly 53k (its my DD) and I'm thinking of switching to synthetic oil. Considering the dealer has been doing free oil changes (conventional), should I make the switch or is it too late in the game?
jkemp16 is offline   Reply With Quote
Old 08-11-2012, 09:43 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Never huts to switch to synthetic, especially in these engines.
FSP tuned: 377/389
Old 08-11-2012, 12:06 PM   #3
SC2150
ALWAYS run full syn in these.....the timing chains and tensioners are far to susceptable to wear and deposits...only keep the owners manual reccomended blend in for break-in....full syn only after that.
Old 08-11-2012, 08:51 PM   #4
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
That's what I have read . Mobil 1 is cheap at Walmart for 6 quarts. I get the PF-2129 for like $4.
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 08-11-2012, 09:32 PM   #5
NathanRobinson
NathanRobinson's Avatar
Drives: 2011 Camaro
im pretty sure the dealership should be using synthetic oil. i get free oil changes and i made sure they only use synthetic!
NathanRobinson is offline   Reply With Quote
Old 08-11-2012, 09:44 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
When it comes to free they will put in what the engine calls for:
8's will get synthetic, 6's will get synthetic blend.
Sent from my 2LT/RS using Tapatalk
FSP tuned: 377/389
Old 08-11-2012, 10:32 PM   #7
RubyCamaro
Jan
RubyCamaro's Avatar
Definately go synthetic! Mobile 1.
Old 08-12-2012, 12:32 AM   #8
OOLIE
OOLIE's Avatar
Drives: 2011 LS
This I use amsoil myself.
OOLIE is offline   Reply With Quote
Old 08-12-2012, 12:50 AM   #9
stlrammer
Drives: 2017 1SS Blue
Yep synthetic is the way to go. Never too late to start.
stlrammer is offline   Reply With Quote
Old 08-12-2012, 03:18 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
You make the same mistake I ALWAYS make, lol. It's actually Mobil.
FSP tuned: 377/389
Old 08-12-2012, 03:42 PM   #11
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
I use fully synthetic Mobil 1 0W-30. Always try to use synthetic oil. It will help your motor in the long run
Old 08-14-2012, 07:44 PM   #12
Chang
Chang's Avatar
Drives: 2010 Camaro V6 LLT Rally Yellow
I use Castrol Edge Syntec from the 1st oil change.
Then found out that the additive in it are easily break-down after 5000km, oil gets dirty and vehicle performance gets a little weaker, and there is nothing really special in Syntec compare to other synthetic oil like Mobil 1 or Quaker State, then I decided to go with something top-shelf. Tried Amsoil Signature Series 5W-30 after research on the net and definitely love it so far.
Chang is offline   Reply With Quote
Old 08-15-2012, 03:12 PM   #13
Forte
Forte's Avatar
Drives: 2011 2LT/RS CGM W/ Black Stripes
If you don't use the GM/AC Delco 5w30 DEXOS synthetic blend (for v6, full synth for v8) it will most likely void your powertrain warranty. Just a heads up.
Forte is offline   Reply With Quote
Old 08-15-2012, 03:13 PM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
100% INCORRECT!! Any GM Dexos approved oil can be used, here is a list of approved oils:
http://www.gmdexos.com/licensedbrand...sedbrands.html
Just a heads up.
FSP tuned: 377/389
