Old 08-12-2012, 04:07 AM   #1
Crisco
Crisco's Avatar
Drives: Black 2LT/RS
Life Expectancy
day in and day out i dread to see the odometer go up and up and up how long will these cars last???
Crisco is offline   Reply With Quote
Old 08-12-2012, 04:11 AM   #2
Blake_GM
Blake_GM's Avatar
Drives: 2011 Camaro 2SS/RS in IBM
As long as you have money to keep it running?
2011 Camaro 2SS w/RS, Imperial Blue Metallic - Toy.
CAI Inc. cold air intake, SOLO axle-back with j-pipes, Kooks 1 7/8" long tube headers with Kooks high flow cats, GPI SS2 VVT cam + engine goodies and dyno tuned by Ryan/Dr. L99/GPI.
Blake_GM is offline   Reply With Quote
Old 08-12-2012, 04:14 AM   #3
camarozzzz
Drives: Blue
Haha, I know that feel man, I know that feel all too well. Mine is pushing 50 000kms and I worry about it running out of life too! As the guy above me said, as long as you have money to fix it up it will be golden!
camarozzzz is offline   Reply With Quote
Old 08-12-2012, 04:32 AM   #4
camaro-dreamer
camaro-dreamer's Avatar
Drives: 2013 Porsche 981S
The LLT engine used on the 2010 and 2011 Camaros is very similar to the engine used in the 2008+ Cadillac CTS. There are reports of this engine going strong after 150,000 km.
The LFX engine used in the 2012+ Camaro has not been around long enough for a definitive answer.
camaro-dreamer is offline   Reply With Quote
Old 08-12-2012, 04:40 AM   #5
5cents
Dave
5cents's Avatar
Drives: 2011 Camaro SS - Black/CGM Stripes
I think it's all in how you treat it, with proper maintenance, engines nowdays should last 200k or more.
5cents is offline   Reply With Quote
Old 08-12-2012, 05:09 AM   #6
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I am pushing 54,000 miles on my SS and no sign of weakness. Still feels like new. Only thing mechanically is I had to replace the drive line at 36K miles. Most cars are going to have a bad part here and there. Even with a cam and other bolt on performance parts it still doesn't use any oil. This is an awesome built car.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 08-12-2012, 05:12 AM   #7
CookieCk
Drives: 2012 Camaro SS
Well the LFX is pretty much the same engine, so I wouldn't think it would change by that much, but I guess we'll see
CookieCk is offline   Reply With Quote
Old 08-12-2012, 05:49 AM   #8
Neumatic
Drives: 2010 Camaro 2SS M6
My SS just past 60k miles, zero mechanical issues.
Neumatic is offline   Reply With Quote
Old 08-12-2012, 06:56 AM   #9
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
I don't understand why people get so worked up about the distance a car has traveled. I never have.
While it is an indicator of use, that is just a raw data point. One data point is not the whole story.
I can ruin a car within 10 km. But the odometer will read only 10 km, and it will be a very low odometer reading vehicle, correct? But it will be in poor condition
In the 21st century, materials are chosen with greater care. Techniques are much better, quality overall is high compared to cars from even a decade or two ago.
For example, primers on metals are now 'weld-through' primers. Tolerances are more tightly controlled overall. Rev limiters are commonplace now. ECUs can prevent engine damage. Relax and enjoy your car
Shocks, struts, brake pads, these things are consumable items anyway. Your car will last a long time.
ChrisBlair is offline   Reply With Quote
Old 08-12-2012, 06:59 AM   #10
ChrisBlair
Buick 455 Fan
Do you mean "drive shaft"? I'm not ignorant of automotive terms; it's just that if you ask ten people from various areas to describe their "drive line", you'll get ten different answers
Old 08-12-2012, 08:27 AM   #11
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
Ive had my SS for almost three years with zero problems. Then again, the car only has 18K miles.
bumblebeecamaro is offline   Reply With Quote
Old 08-12-2012, 08:32 AM   #12
stlrammer
Drives: 2017 1SS Blue
Same here almost 3 years now 17K miles (500 from Camaro5 Fest III but well worth it) and no issues.
stlrammer is offline   Reply With Quote
Old 08-12-2012, 08:41 AM   #13
derklug
derklug's Avatar
Drives: 12 Boss 302
What could realistically be expected from a Camaro:
Body... unlimited for most since they are typically garaged in winter
Engine...Before major engine work, 150K miles on V-8's or 120K on V-6's DEPENDING on proper maintenance.
Transmission...150K on auto, Stick 1k-200k on clutch(very driver dependant) unlimited on trans.
Wheel bearings, rear ends, suspension all come in about 100k
Biggest repair expenses for most under 100k will be for A/C
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 08-12-2012, 08:44 AM   #14
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
what exactly is proper maintenance. i get different answers all the time
