Old 08-21-2012, 02:26 AM   #1
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Question best plug wires for LTs?
I've been told the stock plug wires may crap out soon after header install, due to their orientation putting them a bit too close to the new, more substantial pipes.
I've got a misfire at the moment- got new plugs, but going to replace plug wires as well, to be thorough.
Any suggestions?
Old 08-21-2012, 03:10 AM   #2
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
If you're worried, just get sleeves.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 08-21-2012, 03:15 AM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
In other words, the stock ones are fine.
Old 08-21-2012, 04:34 AM   #4
2010SSRSM6
2010SSRSM6's Avatar
I've had my stock wires on with my LT's for almost 30k miles.
What headers are you running? I've got BBK's and haven't had an issue. Did a wire make contact with one of your pipes? If that's the case, I'd look into heat shields.
Old 08-21-2012, 09:49 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
The stock wires work just fine but aftermarket wires work great too. The key when adding headers is making sure the wires won't have any contact with the headers. A set of wire boots will usually keep them from burning up and generally it's just a plug or two that ends up being an issue.
Juiced1 is offline   Reply With Quote
Old 08-21-2012, 10:08 AM   #6
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Revo....to answer your question.....Granatelli wires is what you want!!! They even have a "high heat" variation that is really sweet......but they are expensive!!!
blazzin1 is offline   Reply With Quote
Old 08-21-2012, 10:12 AM   #7
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
I went MSD with added Heat Wraps
MSD @ 50 OHM's and 70$ heat wraps @ 30$
Grantinellies over 200$ <<< Ouch but 0 Ohm
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-21-2012, 11:01 AM   #8
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I just got the Granatelli 0 OHM high heat wires from Jannetty Racing. Looking forward to get them on a long with my headers. As stated above, they will cost you more than the others, but thats what you have to do to get the best.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 08-21-2012, 11:05 AM   #9
Revo1
Drives: 2010 2SS/RS
Cool, thanks for the input fellas. I'm not seeing any direct contact with the wires so far, so it could be just a plug. The headers are 1 7/8" stainless from XS power...
Will look into some sleeves for sure, can't pay for granatellis at the moment.
Old 08-21-2012, 11:48 AM   #10
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
What wire sleeves is everybody using?
I just got some new plug wires so I might as well throw these on as well.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 08-21-2012, 12:16 PM   #11
NDC123
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally
I went with MTI hot spark wires colored to match my engine bay.
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
NDC123 is offline   Reply With Quote
Old 08-22-2012, 07:52 AM   #12
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
me too, they look great and perform as expected.
Old 08-22-2012, 07:56 AM   #13
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Any suggestions?
I was told I really did not need to change them, but I figured I was already there and it added color to the engine compartment. Mine are by Taylor. Everyone has their opinion on what they feel is best. I went with these because I liked the look, fit, and price. You will notice some of the other brands being sold you have to over stretch to get a good fit. Not the case with these. I ordered through Maryland and had then shipped to my door for $65.
newagemuscle is offline   Reply With Quote
Old 08-22-2012, 08:42 AM   #14
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Did you actually ohm them out? I have an almost new set of MSD's I bought over a year ago. I checked them and they were all over the place. The stock wires were pretty consistant, the Granatellis were as advertised. I don't mind resistance that is high like the stock wires but I do like consistancy. I have a post on here somewhere showing the measured resistance of each set.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
