Old 08-21-2012, 02:31 PM   #1
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
engine cover wont fit in? v6ers. help?
idk where should i start. hmmmm. i know its just a matter of taking out the oil cap, but.....
so couple months ago i installed the black ice-olator that i bought from BNRacing and a strut brace from BMR.
http://www.camaro5.com/forums/showpo...4&postcount=40
http://www.camaro5.com/forums/showpo...6&postcount=20
the mechanic told me when they finished installed the black ice-olator that the engine cover wont fit on my car because there's no more gap between the Intake manifold to the strut brace.
so is there any solution to make the engine cover fit in? i know its not a big deal for me, but its just looks kinda ugly to me without the engine cover.
do i need to change to other brand for the strut brace? or what?
Originally Posted by Nightfall View Post
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune |
My Build Thread
kenkartasasmita is offline   Reply With Quote
Old 08-21-2012, 02:33 PM   #2
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
With the added strut brace, I don't know that you have a fix for the way it is now. When I added the ICE-Olator I had to add a, extra 5/8" nut to the existing little pillar (for lack of a better word, the metal thing that sticks up that the engine cover pops into) to make it long enough to fit with the extra height.
You may need to look at another strut tower brace with more clearance. However, I don't know which one would have any more clearance; I don't think it varies too much between manufacturers though I could be wrong. You'd need to do some measuring.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 08-21-2012, 02:51 PM   #3
garcmol
garcmol's Avatar
See where it rubs and break out the Dremel tool! For the cover, not the brace. But like Belle said, you'll need some sort of extension for it to lock down securely.
Old 08-21-2012, 03:17 PM   #4
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Had the same combo, only had a 1/4" clearance between the plenum cover and brace. Ended up taking the brace off.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 08-21-2012, 03:26 PM   #5
kenkartasasmita
COTW [4/23/12]
i understand what u mean. yeah but i havent seen anything like that in here. i dont much about the choices of strut bar for the v6.
yeah belle said maybe i should check with other brand with better clearence.
do u feel any different on the handling before and after u took off the strut brace?
My Build Thread
Old 08-21-2012, 04:03 PM   #6
Yellow_Glide
I haven't been able to tell a difference. I put mine on more for the wow factor - if it's got a strut brace it's got to be fast - right?
Old 08-22-2012, 03:54 AM   #7
kenkartasasmita
COTW [4/23/12]
its not adding power but it'll make less understeer when u cornering.
My Build Thread
Old 08-22-2012, 04:08 AM   #8
Chevrole+
Chevrole+'s Avatar
Drives: 2010 Camaro 2LT
take it off and polish the motor
Chevrole+ is offline   Reply With Quote
Old 08-22-2012, 06:47 AM   #9
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
The OEM strut brace, standard on 2011+convertibles, will fit and give plenty of clearance, but:
1. You'll have to drill more holes in your strut towers to mount it.
2. You'll have to use spacers between it and the towers since the shape of the towers are different
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 08-22-2012, 09:43 AM   #10
kenkartasasmita
COTW [4/23/12]
nah, that's uncessary tho. its a dd.
yeah but when i saw the OEM Strut brace it doesn't very practical somehow. i dont know maybe bcs it didn't attach to the suspension bolt.
My Build Thread
Old 08-22-2012, 04:01 PM   #11
tmac1granger33
NM HT5
Drives: COTW 3/5/12
im watching this closely, i dont want to lose my engine cover, so what people are doing is dremeling down the engine cover? i have the balck ice, and may be getting the same strut bar
tmac1granger33 is offline   Reply With Quote
Old 08-22-2012, 04:21 PM   #12
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
I ave been needing to ask. What is the strut bar used for exactly.
Old 08-23-2012, 04:05 AM   #13
Chang
Chang's Avatar
Drives: 2010 Camaro V6 LLT Rally Yellow
i have a black ice and a plenum spacer installed, have to take off the engine cover. I think the engine cover is blocking the heat to release from inside the hood somehow anyway.
I'll have a strut tower brace soon but still debating about OEM+spacer or Hotchkis.
Current mods: Flowmaster AMT Axle-back | RX Catch Can | RX Breather | Vararam DZ-6 Intake | Vmax CNC Ported Throttle Body | RX Ported Intake Manifold | Mace Plenum Spacer | Mace 25mm Insulator | BMR Level 3 Handling Kit | BBK Stainless LT header w/ HFC | Magnaflow Res. X-Pipe |
On the way: Trifecta Tune
Future mods: DONE!
Chang is offline   Reply With Quote
Old 08-23-2012, 07:38 AM   #14
kenkartasasmita
COTW [4/23/12]
some ppl said it'll make the car more rigid.
yeah autozone's guy told me about this thing. he also owned a v6. but sometimes if u go to a carshow doesn't it look ugly without an engine cover. well, i dont know why the oem just dont seems very pratical becuase u just drilled the strut tower without tightening the bolts on top of the strut tower.
well i asked Kyle from bmr if they could do some magic with the strut but he told me to ask the ppl with the same combo.
My Build Thread
