Old 08-28-2012, 08:19 PM   #1
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Fog Light HID's for ZL1
Has anyone put 55Watt HID's in the lower fog light of the ZL1 front? Any danger of too much heat and the bezel melting? Was thinking of getting an H11 3000K 55 Watt kit.
CamaroFTW is offline   Reply With Quote
Old 08-28-2012, 09:06 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
55w HIDs will melt the housing. Heck you risk melting the housing with 25w HIDs
Click to view my build thread
Old 08-28-2012, 09:25 PM   #3
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
I had 55w HIDs I'm my first gen CTS-V. Good god they were bright! The V had a rather large fog light housing though.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 08-28-2012, 10:21 PM   #4
CamaroFTW
CamaroFTW's Avatar
Well HID's are only generally in 35 and 55 and I am pretty sure 35 is no problem as these give off very little heat. Was hoping someone actually tried 55 and 35 watt and could comment.
Old 08-28-2012, 10:32 PM   #5
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Here's what happens with a 35W HID bulb.
http://www.camaro5.com/forums/showpo...5&postcount=33
RoketRdr is offline   Reply With Quote
Old 08-28-2012, 11:10 PM   #6
CamaroFTW
CamaroFTW's Avatar
Yeah well that looks like a pic of a DRL housing and not the bottom fog light projector. May have to experiment myself as the fog light I think is glass not cheap plastic like the DRL's. No reason it cannot take a 35 watt HID IMO
Old 08-29-2012, 07:42 AM   #7
The Stig
The Stig's Avatar
The bottom fog light on the ZL1 is the same housing as the DRLs on the Camaro.
If you think 35w will work then I say go for it. I'm just warning you, 35w has melted some people's housing.
Old 08-29-2012, 12:02 PM   #8
CamaroFTW
CamaroFTW's Avatar
OK will check it more this weekend..thanks for the advise.
Old 08-29-2012, 12:45 PM   #9
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
I think the ZL1 DRLs are the same as the Camaro fog lights.
1MtnGoat is offline   Reply With Quote
Old 08-29-2012, 01:04 PM   #10
CamaroFTW
CamaroFTW's Avatar
Yes but I have a ZL1 front and so maybe that is why people are confused. I am taking about the small ZL1 fog light and NOT the DRL. I think the small fog light should take a 35 watt HID.
Old 08-29-2012, 01:07 PM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I would just run it for a wile and see how hot it gets. it is most likly a differnt material. I just bought some heon OEM color matched bulbs as I did not want to mess with hid's in the fogs.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 08-29-2012, 02:31 PM   #12
The Stig
The Stig's Avatar
The fog light housing (not the DRL, but the smaller one on top) is made of the same plastic as the camaro DRL housing. So if the DRL housing can't handle 35w I don't think the smaller housing will either. My .02
Old 08-29-2012, 03:02 PM   #13
CamaroFTW
CamaroFTW's Avatar
the smaller one is on the bottom (not top) and is supposed to be the fog light..the larger one on top is the DRL.
But it may not work...may try it though..
Old 08-29-2012, 03:25 PM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the lenses may be different material though at that woud be the key. the fog has a projector style lens where the running light just has a normal lense. I agree it is a risk though that is why I just did color matched bulb not worth the risk to me.
2016 2SS
