Old 08-31-2012, 11:14 AM   #1
Redline Motorsports
Redline Motorsports's Avatar
Drives: Several...
Defective supercharger cooler brick...FYI..
We where wondering why we where loosing coolant in the supercharger coolant system.
Just putting it here for a FYI in case someone has the same issue as we've seen this before.....this is not meant to start panic attacks which are known to happen on forums.....LOL!
Howard
Redline Motorsports is offline   Reply With Quote
Old 08-31-2012, 11:30 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Meth' injection!!! Hey - you guys just did a feature with GMHTP - what's the problem
jk
That's a little scary. Is there a pump upgrade or anything on your car? I can't remember reading anything along those lines, and I'm not suggesting that could cause something like this, but that's pretty interesting...
'20 ZL1 Black "Fury"
Old 08-31-2012, 11:44 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Howard
That is one way to put out the Fire
Good to know you found it, thanks for Sharing.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-31-2012, 11:49 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Wasn't spraying a tiny bit of water the way to clean-out the combustion chambers back in the day?...
Old 08-31-2012, 12:08 PM   #5
Redline Motorsports
Drives: Several...
Cleanest TVS blower I've seen inside! Good thing we where running water...
We also haven't spray anything in this blower either...
Good ole crap parts.
Howard
Old 08-31-2012, 01:39 PM   #6
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
was that with the stock pump or did you upgrade the IC-pump? I remember reading about someone who installed a bigger meziere pump.
(The added pressure on all those components would be my biggest concern if i'd upgrade the pump...)
MrDew is offline   Reply With Quote
Old 08-31-2012, 01:48 PM   #7
Redline Motorsports
Drives: Several...
Nope. Stock pump and stock Heat Exchanger....
Pure crap part....
Old 08-31-2012, 03:25 PM   #8
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Thanks for sharing!
sammyv is offline   Reply With Quote
Old 08-31-2012, 03:30 PM   #9
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
hope my super chiller doesnt expand and contract mine too much so it cracks :(
joes407 is offline   Reply With Quote
Old 08-31-2012, 03:36 PM   #10
thespymaster
thespymaster's Avatar
The obvious question, how are you planning to FIX the problem on your part?
Anyone on the Camaro Team made aware of your findings?
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 08-31-2012, 03:42 PM   #11
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
How do you check the supercharger coolant level? I know the valve is under the plastic cover on the front. When you open the valve on top is it simply supposed to be a "visual check"...??
htron50 is offline   Reply With Quote
Old 08-31-2012, 03:46 PM   #12
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Just put some Bars Leak in it.
RoketRdr is offline   Reply With Quote
Old 08-31-2012, 03:58 PM   #13
Redline Motorsports
Drives: Several...
Replaced it with another one....the side tanks are paper thin. Not enough to weld..
Howard
Old 08-31-2012, 04:02 PM   #14
Redline Motorsports
Drives: Several...
if its empty its empty!
