Russ
Increasing power without changing speakers
I have the standard BA system in my 2010 SS and am relatively happy with it. I had a sub installed w/ 1100W amp so I have plenty of bass now.
I would like to increase the wattage of the base system but not interested in replacing the factory speakers. Has anyone upgraded their wattage but kept the factory speakers? If so, are you happy about the sound? How much better does it sound? What wattage amp did you replace the factory unit with? Russ |
I have replaced my factory speakers and put in a Fosgate 600.4. I would say be very careful with factory speakers and aftermarket amps. You can easily blow the speakers as they are designed for their rated power. Typically factory speakers are not designed to be powered more than they are already being powered with. It is possible they allowed for some tolerance and you may be ok with adding some more. Just some food for thought for you. Maybe someone will chime in who did this with success.
![]() Drives: 2012 Camaro 2ss Heritage Grill/GFX Join Date: Mar 2012
I have just installed a JL Xd 400/4 amp and kept the factory speakers. So far they are holding up and I have played it pretty loud. Only time will tell though as there are too many variables. (Everyone has a different listening preference) and amp gain to the speakers will be the determining factor. I also have the JL 600/1 and a stealthbox. Plenty of base and highs at a louder listening level but kind of muddy sound at lower listening levels.
Voice Of The Voiceless
Same as above, I started with just replacing the stock BA am with a JL xd400 while keeping the stock speakers. It enhanced the sound and I was pretty happy with it...all the stock speakers have been replaced now
Russ
Thanks for the responses. I think I'm going to buy the amp and leave the factory speakers in for now. If one gets damaged I will simply replace them all.
What's the story about the speakers in the doors being so hard to replace? Are they an odd size or something? Were you guys able to buy and install standard off the shelf speakers? If so please let me know what speakers you purchased. Russ |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
word to the wise..
never put more into the amp that you do the speakers.. the speakers are the end of the line where the sound comes from, I would focus on the speakers long before worrying about an amp, or at the very least do them together.. factory speakers are cheap as they come crap, why spend good money for a nice amp and pump it into crap? |
#7 | |
#8 | |
Russ
I'm not a stereo expert, and that's an understatement. That's why I ask questions before I do something to try to avoid making a mistake. Russ |
#9 | |
Russ
What do these door speakers cost w/ the adapters? Thanks for the info. Russ |
#10 | |
IMO they are crap, I have yet to own a vehicle that had a decent OEM sound system, the Bose in my Avalanche was pretty good, but far from great. but it is my opinion, I am not Tone Deaf, I and my family are full of musicians, I myself play guitar and piano, my daughter plays piano and violin since she was 3 and my wife plays guitar and piano, and 3 of her uncles are all professional musicians. sound is subjective, of course, but to my ears the stock system is junk, hell the sub woofer isn't even a true sub, it has vocals that play thru it, in the 200 to 250k Hz range, it should only play lows below the 100k Hz range, and yes I put a meter on it and tested it. again it is just me, but the rule of thumb has always been get the best speakers you can afford and work backwards to the head unit. |
#11 | |
http://********.com/Chevrolet-GMC-Su...-Adapters.html The existing BA speakers in your car also have adapters. The adapters that ******** sells are available so that you don't have to rip out the old speaker and mess with the old adapter. I bought my Alpine speakers from http://www.dynamicautosound.net/ But, check out ********'s line of component speakers here: http://********.com/Chevrolet-GMC-Su...er-Accessories Steve carries Hybrid Audio, which is a pretty decent brand. However, you will also hear about Focal and Hertz...pretty good brands as well.
#12 | |
Aural Assault Vehicle
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali Join Date: Jun 2011
I think you and I are on the same page (I like the Bose in my Avalanche, but I swapped out my Bose amp for the Escalade Bose amp - made a world of difference). I will say however, that the speakers are not the big weak spot in the factory Boston system. The factory amp is beyond terrible. Replacing the factory amp with a GOOD amp does wonders for the speakers. I ran an old school Alpine 3527S to the front components and the rear woofers and I was impressed. It had a nice, warm sound - I would have been OK with it if not for that speaker pop, but that is the head unit's fault. As for the OP, remember that the Boston speakers are 2 ohm and plan accordingly. I wouldn't recommend an amp with more than 100W RMS per channel. I believe that the 6.5's up front are rated at 50W and the tweeters are rated at 20W.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692 |
#13 | ||
Russ
************************************************** *** Quote:
Russ |
#14 | |
http://www.camaro5.com/forums/attach...1&d=1299982375 I've only had the car for 2 weeks, but the system is crap IMO. I have a few other mods to do first then will tackle the sound system. |
