Old 09-11-2012, 02:48 PM   #1
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Hesistation
I finally have enough miles and a catch can on so I felt comfortable giving the car a good run to see what it would do.
Both times I did it I got it in 1st to 5K RPMS and felt a hesitation. Once it was at 5K and the other time I was shifting from 1st to 2nd.
What gives?
jimmy5 is offline   Reply With Quote
Old 09-11-2012, 03:40 PM   #2
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Was it the supercharger spooling up?
Sven59 is offline   Reply With Quote
Old 09-11-2012, 03:54 PM   #3
fbodfather
fbodfather's Avatar
Keep in mind that the ECM 'learns' as you drive. If you've been breaking it in gently - you may want to disconnect the battery for 20 min - and reconnect. A word of caution: it will idle very roughly for a few minutes - but it will 'relearn' for performance driving.............
Old 09-11-2012, 06:22 PM   #4
fredzl1
fredzl1's Avatar
Drives: 69 Camaro .73z28. ZL1 ordered
I am sure that Fbod has a fix that will work, but I am one who studied for a yr and still didn't understand the modes of power. I thought stage 5 was the max but it still stumbled after breaking loose to catch up. tried just traction off and It became a wild beast spun for 30 yds, backpedaled to hook and it broke free again at shift. That is what I paid the big bucks for. Bad part is I am a few hundred miles early. My 69 I built the motor and ran it like I stole it for the first 300 mies. GM has to be better than me right ?
fredzl1 is offline   Reply With Quote
Old 09-11-2012, 07:04 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
It would be a suggestion then to do the 5 & 20 fuse pull after break in, as with the SS ?
Old 09-11-2012, 09:38 PM   #6
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
Hmmm... so what are the implications of this? Should we be following the 4K rpm limit for 1500 miles to the letter? Is is good for the engine break in period to rev the engine to 3 or 4k in various gears and allow it to wind down on its own (engine braking)? Or is it best to simply drive it gently for the first 1500 as the owners manual seems to suggest? I want to do the right thing but have never had a car before with such a long suggested break-in period.
Any advice would be appreciated...
zl1bro is offline   Reply With Quote
Old 09-11-2012, 10:10 PM   #7
Blueclyde
Drives: 2023 ZLE
I have experienced something similar and am starting to wonder about it. At first I thought it was a rev limiter but it does it prior to 6000 rpm. I'm now wondering if it is the traction control system throttling the engine. Mine does what you describe ocassionally.
Blueclyde is offline   Reply With Quote
Old 09-11-2012, 10:42 PM   #8
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
I've been driving mine aggressive since day one. I haven't noticed any hesitations.
Taser Deployed is offline   Reply With Quote
Old 09-11-2012, 10:55 PM   #9
jimmy5
jimmy5's Avatar
Did it again tonight. Hesitates at 5K rpm and stumbles into the next gear. I will disconnect the battery and see if that helps.
Old 09-11-2012, 11:03 PM   #10
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
You are not listening to Scott, God help you................... JRJ
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 09-12-2012, 12:04 AM   #11
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
+1
ZL1 #612
snapp32e is offline   Reply With Quote
Old 09-12-2012, 12:05 AM   #12
firecross91
firecross91's Avatar
Drives: ZL1 #1691 Black on black.
I've driven mine per breakin, I haven't noticed any hesitation. But will do the disconnect if necc.
firecross91 is offline   Reply With Quote
Old 09-12-2012, 03:33 AM   #13
blackzl1az
Drives: Black ZL1
Originally Posted by snapp32e View Post
+1
+1
blackzl1az is offline   Reply With Quote
Old 09-12-2012, 07:21 AM   #14
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Hook a scanner up to it and seen what's going on. I'm in Austin and have HP Tuners. Not sure how far you are from me, but I have no problem with hooking up and doing a scan on your car to seen what's going on.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
