Old 09-12-2012, 06:04 PM   #1
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
1000HP + FI Guys Check this out!!
It it pretty common for the FI guys that are making 1000hp on a 4 bolt head to have head lifting issues sooner or later. HPS has teamed up with Dafferon Race Innovations and now has a alternative and cost effective solution for keeping your heads down. Pictured below is a customers Aluminum 6.0ltr. with Darton Sleeves that we added the 5th and most crucial head bolt boss to this block. Along with a set of 6 bolt heads or we can even convert the factory heads to use the 5th Bolt that is so crucial for keeping the heads down when exceeding the 1000hp limit.
Stay tuned as we do some testing with this block in the next month!!
Chris
Chris-HPS is offline   Reply With Quote
Old 09-12-2012, 06:06 PM   #2
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
very nice looking for updates..
Whipped416 is offline   Reply With Quote
Old 09-12-2012, 06:46 PM   #3
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Yes, looks great!
CamaroFTW is offline   Reply With Quote
Old 09-12-2012, 07:01 PM   #4
jrpxxii
jrpxxii's Avatar
I found out even 6 bolt heads will lift too.
Old 09-12-2012, 07:07 PM   #5
Graham Behan
Drives: Various
Yep, it's called calibration!
Graham.
Graham Behan is offline   Reply With Quote
Old 09-12-2012, 07:16 PM   #6
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
I need a smoke after that.
That thing is sweet!
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 09-12-2012, 08:47 PM   #7
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Say it aint so? You didn't pop it already did you?
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 09-12-2012, 09:07 PM   #8
jrpxxii
jrpxxii's Avatar
No, no problems just a little too much boost. Just took a little more torque on the bolts. This combo is making insane power and surprised all of us. I was told that Mark Carlyle's vette by IPS has to torque the heads after every pass as it lifts the heads too. I just had one head lift as there were just a couple wet marks so I am still beating the sh%t out it. Where is car, you seem to have vanished?
Old 09-12-2012, 09:19 PM   #9
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 09-12-2012, 09:56 PM   #10
jrpxxii
jrpxxii's Avatar
Did you pop yours? I was expecting 8's by now from you
Old 09-12-2012, 11:08 PM   #11
Unreal
Drives: 2006 Z06
Nice to see options. I'll stick with all 6 bolts.
Nick
Corvette Z06 -1200ish rwhp
Old 09-13-2012, 09:29 AM   #12
Chris-HPS
Chris-HPS's Avatar
There is a big difference in making 12-1400hp then making over 2000hp like carlyl is doing. This is a great option for guys that dont want to spend $2000.00 plus for a Iron LSX Block or even more for the Aluminum race blocks out there. The cost for the added tabs is only $600.00. We will find out what kinda power we can make without issues shortly.
Chris
Old 09-13-2012, 09:33 AM   #13
Chris-HPS
Chris-HPS's Avatar
What heads you using?? Do you know what the deck height is on them?
Carlyle is in a different ballpark in the boost and power then all of us on here as well. He is making close to 50lbs of boost.
Chris
Old 09-13-2012, 09:38 AM   #14
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
pretty sure he is running the Mast heads. I wouldnt think he should be pushing water.
JLE58 is offline   Reply With Quote
