Old 09-30-2012, 08:10 PM   #1
locoycabron
Drives: 2010 Camaro SS
rear 305/45/18 & 11" wheel
hi guys!
is anyone using on the rear 305/45/18 & 11" wheel?
would i need spacers or they go straight in?
thank you.
locoycabron is offline   Reply With Quote
Old 09-30-2012, 08:13 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
They should go staright on, depends on the offset, but you aren't doing anything crazy here.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-30-2012, 08:27 PM   #3
locoycabron
what offset do i need i have 2 options:
53 and 40 offset?
Old 09-30-2012, 08:28 PM   #4
locoycabron
well if none of this 2 options is good for those tire measures what offset do i need for them?
Old 09-30-2012, 08:38 PM   #5
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
Pretty sure you want 40mm. Stock offset is 40, so an 11" wheel will be 1" to the inside and outside. Center of the tire will not move. The added tire width will be equal inside and outside also. 58mm will probably rub on the inside.
You will learn more than you need to know if you do a search for "18x11", and "305-45-18".
ihada69L78 is offline   Reply With Quote
Old 09-30-2012, 10:29 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
I run a 18x9.5 (40mm offset) with a 305/45. Gotta pull the ebrake cable out of the way. That's proven to be harder than I thought. I got it finally...but it ain't real easy.
-John S.
