Old 10-07-2012, 05:21 AM   #1
Legend96
Drives: 2013 ZL1 Victory Red
ZL1 audio upgrade
Please excuse if this has been covered! I haven't seen anything on it if it has!!
I sold my 2011 SS, to purchase a 2013 ZL1.
I took out all the aftermarket stereo equipment I purchased for the SS, in order to put it in my new Z!
I guess the main question in fairly simple! Are all the connections, wiring, etc.. the same on the ZL1?
I did purchase some new things to put in the ZL1!
Those consist of, the drivers side rear mount subwoofer box for the JL Audio 10W7AE from ********.com. To push that, I bought a JL HD 750/1 to push only the 10!
I had purchased in the past was the JL XD 400/4 to take the place of the factory Boston acoustics amp!
Just kinda wondering if all this will be basically the same installing in the new ZL1? I had also purchased the "FARK" kit from ******** as well so it should all be basically plug & play.
Should be starting on this soon, as I do plan on installing dynamat first, then go from there!
Initially, I plan on keeping the stock speakers for now, then maybe upgrading those later!!!
One other small question, how can I disconnect that center dash mounted speaker without prying the grill of and disconnecting it?
I did this on my 2011 SS and the grill came out slightly damaged!!
Thanks for any assistance)))
PS, I ❤❤❤ my Z
Legend96 is offline   Reply With Quote
Old 10-09-2012, 09:12 AM   #2
Rizzo
Drives: 2012 Camaro ZL-1 SIM
I am not sure what kit you have, but be careful for the Scosche:
http://www.camaro5.com/forums/showthread.php?t=246752
Rizzo is offline   Reply With Quote
Old 10-09-2012, 09:15 AM   #3
Steve@Subthump
Drives: 2011 2SS IOM Vert
You won't have to bother with the center speaker. Once you hook up the Fark to the JL amp, the center speaker will become unused.
Steve@Subthump is offline   Reply With Quote
