Old 10-09-2012, 05:51 PM   #1
Unfkwthabl
Unfkwthabl's Avatar
Drives: 2011 V6 Synergy Green Camaro
Will These speakers work
Looking to replace my OEM speakers with some aftermarket ones and am wondering if they will fit and work correctly. I want to use
Rockford Fosgate Punch P1652-S for front door and tweeter.
http://www.crutchfield.com/p_575P165...-S.html?tp=105
Rockford Fosgate Power T1675 for rear 6x9 replacement
http://www.crutchfield.com/p_575T167...75.html?tp=105
Will these work for the setup I am looking for. I plan on upgrading the head unit later on but want this for now. Will I need to run an amp with this setup. If so can someone point me in the right direction of one that will work well with this setup. Thanks in advance.
Unfkwthabl is offline   Reply With Quote
Old 10-09-2012, 06:26 PM   #2
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Yes, they will both work, you will need to get the adapters from ********.
=Stephens= is offline   Reply With Quote
Old 10-09-2012, 09:51 PM   #3
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
I would highly recommend going with Power Series speakers up front as well. The front is much more important than the rears.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 10-16-2012, 05:51 AM   #4
2010SSRSM6
2010SSRSM6's Avatar
2nd the power series if your set on RF.
You will need a much better amp no matter what speakers you choose. The BA amp is crap (if you have the BA system).
If you're basing your decision on price, shop around a little. Find a Hybrid Audio Technology dealer and check out their Mirus line (their entry level line), for the price, you will be hard pressed to find a cleaner sound.
Amp wise, again price is important, but I'm partial to Arc Audio. I spent years doing shows with RF stuff and don't regret the switch one bit. If I were on an unlimited budget, I'd go with Audison for the amp.
Old 10-16-2012, 11:42 AM   #5
Forte
Forte's Avatar
Drives: 2011 2LT/RS CGM W/ Black Stripes
Arc is a good product, but they don't seem to make any mono amp with major watts. Would highly recommend for components/6x9's though.
Forte is offline   Reply With Quote
Old 10-16-2012, 12:47 PM   #6
2010SSRSM6
2010SSRSM6's Avatar
Not sure what you consider "major watts, but their XDi2000.1 is rated at 2000wrms @ 1 ohm. The XD line is their entry level line. If you wanted to get really crazy the Signature Edition (top line) SE 4000 is good for 4000wrms @ 1 ohm with a .05% THD or you can "strap" two of them together and get over 10,000 watts.
To me, that is MAJOR watts. I blew the rear hatch out of my 5.0 with a hell of a lot less and I've seen windshields pushed out of cars at that level.
Old 10-16-2012, 01:31 PM   #7
Forte
Forte's Avatar
Never seen those, i've only even seen a 500 mono from them before. Good to know! I love their 4 channel's though
Old 10-16-2012, 04:04 PM   #8
2010SSRSM6
2010SSRSM6's Avatar
