Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 10-23-2012, 03:24 PM   #1
bomberro71
Drives: 2010 camaro ss
Dash board
I just put on some 22" rims on my car. As I was driving out of the parking lot, my lights on my dashboard lit up. The car drives fine but my dashboard is lit up like a Christmas tree!! Could someone tell me how to turn this off.
bomberro71 is offline   Reply With Quote
Old 10-23-2012, 03:34 PM   #2
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
got to be more specific then that. the ONLY light that could be on due to your rims is the tpms system. but to be "lit up" kinda confused on that one. take a pic of the dash. and then people can help you better.
are they 22's that actually fit the car? are the tpms learned on the car? were the rims installed by u or a shop
if its a reputable shop that did it then they might not have transferred your tire pressure sensors... and if they did transfer them then they should relearned it before you got your car back
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 10-23-2012, 03:41 PM   #3
bomberro71
The rims do fit my car perfectly the sizes are 22x9 in front with 265 30 22 tire and 22 x 10 in back with 285 35 22 tire. They where installed by a shop and they did put the tire sensors on the rims. When I was driving my car, a message came on the dash stating stability track service. Then all my lights turned on that included ABS BRAKE and the traction control icons turned up as well. Im thinking my car needs to be re calibrated because of the bigger rim?
Old 10-23-2012, 03:42 PM   #4
AKA-51
Drives: Ellie
pics
AKA-51 is offline   Reply With Quote
Old 10-23-2012, 03:48 PM   #5
bomberro71
Ill send them
Old 10-23-2012, 03:52 PM   #6
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
I put 22's on myself and nothing like this happened at all, no lights came on
austinjames is offline   Reply With Quote
Old 10-23-2012, 04:03 PM   #7
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
had the same issue, its not the rims, its your tire sizes. cant be more then .5 difference from front to back... use a tire calculator to find out if thats the issue.
MARINE1991 is offline   Reply With Quote
Old 10-23-2012, 04:04 PM   #8
MARINE1991
MARINE1991's Avatar
just saw this yep thats the issue.. you need the 35 upfront and the 30 in the rear. thats the issue.
Old 10-23-2012, 06:21 PM   #9
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
He doesn't want 35 up front with those sizes though.
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
OP your rear tires at 285/35/22 would be 29.85" tall compared to your front 265/30/22 is 28.3" They need to be as close to eachother as possible. As marine1991 said, within .5"
Can you confirm those are in fact the tire sizes you have? If so, your wheel shop screwed the pooch.
Obzen is offline   Reply With Quote
Old 10-23-2012, 06:24 PM   #10
MARINE1991
MARINE1991's Avatar
Can you confirm those are in fact the tire sizes you have? If so your wheel shop screwed the pooch.
Yea I just know the tire sizes are wrong, and should be higher on the middle number then the rear..
Old 10-23-2012, 08:17 PM   #11
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Yes sir. You are correct. Or in this case the same size but definitely not higher in the rear. That's never a good idea.
Old 10-23-2012, 08:22 PM   #12
MARINE1991
MARINE1991's Avatar
yea learned that the hard way too... theses tire shops have no idea what they are doing...
Old 10-23-2012, 10:19 PM   #13
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Yeah. They just look at the width and say "uh yeah that'll look great, gimme money!"
Old 10-23-2012, 11:09 PM   #14
zkdreads
zkdreads's Avatar
good luck. keep us posted on what they say... hopefully they wont tell you to kick rocks
C-LO or Sonic
