Old 11-12-2012, 08:22 PM   #1
CamaroW&b
CamaroW&b's Avatar
Drives: SS / ZL1 Kit retrofit
Unhappy ABL lighting issue !!
Hi guys
I have Camaro 1SS and I installed the silver door panels for the 2SS:
http://www.shopchevyparts.com/interi...-92252134.html
And I bought the Ice Blue LED harness for the ABL lighting:
http://www.gen5diy.com/index.php?rou...&product_id=61
The problem I faced is that the ABL lighting from the harness is too too dim to a degree that it doesn't glow along the pipe ( Tried many different pipes ). It's like nothing changed.
Can anyone please tell what's wrong with it? Is it from the harness or from the car itself ??
Thanks.
CamaroW&b is offline   Reply With Quote
Old 11-12-2012, 08:23 PM   #2
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
get a hold of 2ssrs he can help you out no issues...
MARINE1991 is offline   Reply With Quote
Old 11-12-2012, 08:42 PM   #3
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
did you plug it in the door or t-tap? The 1ss/1lt plug is dead. You wont see hardly any light like you are talking about. I went to the dealer to program my 1lt like a 2lt but they were too incompetent to get this done. I ended up t-taping into the window switch.
Indy Bumble Bee is offline   Reply With Quote
Old 11-12-2012, 09:07 PM   #4
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
The tube has to be the right kind. I used two lamps for the right side. And one lamp for the short side witch is the drivers side. 2ssrs is the one you seek.
chevy 3 is offline   Reply With Quote
Old 11-12-2012, 09:08 PM   #5
Indy Bumble Bee
Drives: Beest
Your talking about across the dash. He is having problems with the door abl
Old 11-12-2012, 09:23 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Do you have the brightness up on the interior lights? There's a switch that scrolls by the light control next to the steering wheel.
Old 11-13-2012, 12:16 AM   #7
CamaroW&b
CamaroW&b's Avatar
No, there was i thing I plugged the harness in. The dealer couldn't do anything for me too. He thought that I need to buy a wire that can splits for placing to harnesses to make it brighter but it didn't work.
So you mean by taping it with the windows wires, you connected it with the harness wire together? Did it work?
Old 11-13-2012, 12:18 AM   #8
CamaroW&b
CamaroW&b's Avatar
Yah I thought this was the reason but it wasn't. It's about the harness thing.
Old 11-13-2012, 07:47 AM   #9
Indy Bumble Bee
Drives: Beest
http://www.camaro5.com/forums/showthread.php?t=254943
Here is my thread... Post 14 shows tells you what wires to tap into. It is not ideal to t-tap but it works just fine. By taping into the window switch, you can adjust the light from dim to bright. It is frustrating that some on here can get it programmed and not have to t-tap with no problem. T-taps are very cheap and is extremely easy to do. It takes 4 t-taps (2 for each door) 18-22 guage. pm me for question. I did this a month ago.
