Old 12-14-2012, 08:43 AM   #1
OPP
OPP's Avatar
Drives: 2018 MBM ZL1 Auto
What does porting mean on a throtle body?
I'va searched and searched and nowhere can I find a description of porting a throtle body. What is so special about a ported TB? Seems to me that it is larger internal diameter TB. Is that right? Then why the hell the term "ported". What does ported mean?
OPP is offline   Reply With Quote
Old 12-14-2012, 08:58 AM   #2
Bo White
Bo White's Avatar
Porting anything is the process of reshaping to enhance fluid dynamics weither it be cylinder heads, intakes, throttle bodys or even oil pumps.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-14-2012, 09:14 AM   #3
SC2150
Lots of info here if you search....from basics to full technical data.
Old 12-15-2012, 03:29 AM   #4
POS Dakota
POS Dakota's Avatar
Drives: GMs and Chryslers
Nothing.
POS Dakota is offline   Reply With Quote
Old 12-15-2012, 06:27 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The inner throat of the throttle bodies is not a straight thru round tube, but an uneven design with dips and humps. The first modification is to straighten and smooth these imperfections as much as possible. Then a pattern is cut into the surface (think golf ball). The texture breaks surface tension and allows the intake air to flow equally in the center as it does around the sides. The result is increased velocity which translates into improved throttle response and power.
Old 12-15-2012, 08:24 AM   #6
OPP
OPP's Avatar
I did and did not find a straight answer.
Old 12-15-2012, 08:25 AM   #7
OPP
OPP's Avatar
Thank you!
Old 12-15-2012, 04:47 PM   #8
Apex Motorsports
Thank you!
No problem. If you have any other questions feel free to send me a PM or give us a call.
Old 12-17-2012, 05:50 PM   #9
LSR SAL
LSR SAL's Avatar
Drives: faster than dirt...
yep what this guy said
LSR SAL is offline   Reply With Quote
