Old 01-14-2013, 10:07 PM   #1
amm__x
Drives: 2011 camaro
200 shot of nitrous
(235/251 .621/.624) 113 LSA
i have the that cam on ls3 m/t with pulley& Corsa & kooks and Vararam ram i maed 490 whp and 438 wftlbs
i added fast 102 and NW 102 i got 522 whp and 460 wftlbs
i am planing to add 200 shots of nitrous 3.9 what do you think?
and if i need it zl1 fuel pump
amm__x is offline   Reply With Quote
Old 01-14-2013, 10:14 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Would be best to go w/ a dedicated fuel supply...
Old 01-15-2013, 02:05 PM   #3
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Def need seperate fuel system and use 116 octane in it as I do. I would stick to a 150 shot for regular use though.
Maybe a 200 shot once or twice lol
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 01-15-2013, 03:18 PM   #4
blackonblacksls
Drives: 2011 2ss/rs
I'm selling a dedicated fuel system if your interested.
But on another note I sprayed a 175shot on my g6x3 cammed car stock fuel system
blackonblacksls is offline   Reply With Quote
Old 01-15-2013, 03:28 PM   #5
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
So you made 32hp and 22tq just swapping intake and tb, same dyno?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 01-15-2013, 03:38 PM   #6
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
he would have probably got similar numbers with a ported stock TB and ported LS3 intake, seems to be the norm... that is what kills me, people will port on relatively stock LS3s/L99s and then moan about the lack of gains, until you do a cam swap, its not going to be a decent gain
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 01-15-2013, 03:51 PM   #7
inferno camaro
My cam is 238/245 603/618 114 lsa and supporting mods. I'm looking at doing mast black label heads and trying to figure out what to do for an intake. I;ve been told the fast would pick up 20-25 hp over ported and also been told makes no more than ported with my vmax tb.
Old 01-15-2013, 04:02 PM   #8
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
You need a forged rotating assembly with that too.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 01-15-2013, 05:54 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
A ported Ls3 will not have the same gains as a FAST with his combo. Sorry but a stock 90mm TB that's been cncd and still 90mm will not be the same as a NW 102 with his combo. The ported TB make for better Throttle response that ill agree with.
OP do you know which system your gonna be using? And how often will you be using the dope?
Old 01-15-2013, 06:11 PM   #10
2SSRSinBama
http://forums.corvetteforum.com/c6-t...s3-intake.html
they picked up 8hp/7-ft.-lbs with a FAST 102 intake/NW 102 TB and 7hp/5 ft-lbs with a ported LS3 intake and ported throttle body...
Old 01-15-2013, 08:41 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Umm did you see his cam specs? Looks like bigger cam sir....
224 / 236 .581 / .601 lift, 113 LSA ----used for the test you linked
Vs
235 / 251 .621/ .624 lift, 113 LSA
Moving more air.
OP and with that cam you'll get ALL the 200 shot lol
Old 01-15-2013, 11:06 PM   #12
amm__x
Drives: 2011 camaro
thanks guys
