Old 01-31-2013, 09:05 PM   #1
Speechsteve
Speechsteve's Avatar
Drives: Chevy
Intercooler question
What type of fluid is in the intercooler aaaannddd..how do you add fluid?
Thanks,
Steve
Speechsteve is offline   Reply With Quote
Old 01-31-2013, 09:14 PM   #2
gearhead08
gearhead08's Avatar
Drives: 2018 ZL1 A10 and 2013 GT500
I would do some research but it will be some sort of water/ coolant blend. You should have a fill cap at the top of your coolent resevoir to fill add funnel then pour fluid in.
gearhead08 is offline   Reply With Quote
Old 01-31-2013, 09:16 PM   #3
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
How do you actually check the fluid level
CAM....ZL1 is offline   Reply With Quote
Old 01-31-2013, 09:19 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
dexcool and the little black cap on one of the intercooler circuit lines (first remove red engine cover and look on top of supercharger). Rotate the cap to up position and remove the little clip and pop off cap to top off. Once you refill the system and replace the cap + clip, rotate the fitting with the cap to the left. It is a closed system. If you havent drained the coolant out of the IC circuit, I doubt it needs to be touched. There isn't a reservoir like a GT500 if you were first wondering. You can add an aftermarket unit if you are so inclined.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-31-2013, 09:44 PM   #5
gearhead08
gearhead08's Avatar
Oops well I tried figured it would have its own resevoir.
Old 01-31-2013, 10:12 PM   #6
DangerZL1
Drives: 2023 Black ZL1 Auto
That's one of the reasons it heat soaks so quick.
DangerZL1 is offline   Reply With Quote
Old 01-31-2013, 10:19 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It does?
Old 02-01-2013, 05:39 AM   #8
Speechsteve
Drives: Chevy
Here's the next question..can you add redline water wetter to the intercooler to reduce temp?
Old 02-01-2013, 05:43 AM   #9
Stephen12ZL1
Drives: '21 ZLE A10
You can do that but I bet you will have to remove some fluid first to prevent overfilling and spilling it.
Old 02-01-2013, 08:54 AM   #10
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
DexCool/water.
KD Innovations is offline   Reply With Quote
Old 02-01-2013, 08:55 AM   #11
KD Innovations
No, not really at all. If you add a bigger HX and the temps will really come down.
Old 02-09-2013, 10:05 PM   #12
gkviper192
gkviper192's Avatar
Drives: TBSS
If you drained some of the stock HE fluid you can't add water wetter?
gkviper192 is offline   Reply With Quote
Old 02-10-2013, 04:21 PM   #13
Speechsteve
Drives: Chevy
I used water wetter in my motor and it lowered the temp by 20 to 25 degrees or so..
Old 02-10-2013, 04:37 PM   #14
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Maybe it was out of water...
Flavorwrench is offline   Reply With Quote
