Old 02-18-2013, 07:23 PM   #1
spyderbuddy
Cito Premium Vs Shell Premiuim
I found a Citgo Gas station in Albany that has pure gas.
Premium
Mid grade
Regular
I would like to know if citgo gas is good gas or as good as Shell.
Old 02-18-2013, 07:25 PM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Isn't Citgo the national oil company of Venezuela's retail sales arm?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 02-18-2013, 07:27 PM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
There isn't much difference between gas, particularly between branded gas.
Personally, I'd use ethanol free fuel anywhere I can get it.
Here's a useful link for you as well. It's a bit hit-and-miss sometimes because anyone can edit it, but it is still useful none-the-less.
http://pure-gas.org/index.jsp?stateprov=GA
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 02-18-2013, 07:32 PM   #4
mikeyg36
Drives: 2015 Z/28 #533
John B.
Yep
mikeyg36 is offline   Reply With Quote
Old 02-18-2013, 07:34 PM   #5
spyderbuddy
I guess my question should be:
Shell with Ethanol or Citgo with out Ethanol
I put 5 Gallions in my car today, almost emtpy < 1/8 tank so I could get home till I get gas from my station I normally get.
I usually get gas at a Shell station that has Ethanol in it. E10
Old 02-18-2013, 07:35 PM   #6
mikeyg36
I would stick with the Shell.
Old 02-18-2013, 08:18 PM   #7
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Citgo is owned by the socialist nightmare we call Venezuela, so none of my greenbacks will ever go there.
Thank you.
tonyko1 is offline   Reply With Quote
Old 02-18-2013, 08:23 PM   #8
spyderbuddy
Thank you.
wow, all I needed was gas and they were the closest at the time.
Old 02-18-2013, 08:46 PM   #9
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
Well just in case you ever wanted to know
06_warrior is offline   Reply With Quote
Old 02-18-2013, 08:48 PM   #10
ZL1ster
ZL1ster's Avatar
Drives: '13 ZL1 IOM M6
Thank you.
+1
ZL1ster is offline   Reply With Quote
Old 02-18-2013, 08:55 PM   #11
fielderLS3
fielderLS3's Avatar
Thank you.
Yeah, but isn't Shell owned by the socialist nightmare we call the Netherlands?
Old 02-18-2013, 09:05 PM   #12
chipknr
Drives: 2016 Black Camaro 2SS
Premium
Mid grade
Regular
Citgo gas is not a "Top Tier" fuel which means it only contains the EPA minumum required amount of detergents, that said Shell should be the only choice for your Camaro.
chipknr is offline   Reply With Quote
Old 02-18-2013, 09:11 PM   #13
spyderbuddy
I had heard there was a station that had straight gas not and ethanol mix. And had heard that Ethanol free will make your car run better.
I just wanted to try it.
Old 02-18-2013, 09:46 PM   #14
fielderLS3
fielderLS3's Avatar
"Top Tier" is more of a gimmick than anything. Just one of many. Every brand has their own marketing terminology do describe the same, or at least very similar things. I'd rather have non-"top tier" pure gas than "top tier" gasohol any day.
Even if there was a very minute difference, a tiny difference in carbon buildup over 150k miles can be sea-foamed out in 20 minutes. The corrosive effects of ethanol are worse and permanent.
