Old 02-19-2013, 08:23 AM   #1
CamaroDIYking
Drives: 2010 Camaro 2SS/RS
Removing brake calipers
Can someone tell me how to remove the brake calipers ? I have tried and have no clue what to do.
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights.
Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps.
Exterior lights- tinted tail lights and sidemarker lights.
Wheels- powdercoated stock RS 20' wheels black
Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete.
Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros.
CamaroDIYking is offline   Reply With Quote
Old 02-19-2013, 08:25 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Doyou want to totally remove them? If so I would not do it unless you know how to bleed brakes.
If you just want to take them off but not remove from the brake lines, here you go.
http://www.camaro5.com/forums/showthread.php?t=135887
What are you attempting to do excatly?
FSP tuned: 377/389
Old 02-19-2013, 08:29 AM   #3
dwinva
dwinva's Avatar
Drives: 13 2SS/RSvert,CRT,dual-mode exhaust
Kind of an ironic question, given your C5 name. If you don't know but are hell bent on doing this, do yourself a favor and get an AllData.com account. (I think it's like $17 for a year.) Set up your account with your year, make, and model and you can access all you need to learn how to do this. You can even access diagrams you may find very useful. Good luck.
dwinva is offline   Reply With Quote
Old 02-19-2013, 08:30 AM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
I was thinking the same thing. But good for the OP for tyring, that is how you learn and become a DIYKing.
FSP tuned: 377/389
Old 02-19-2013, 08:44 AM   #5
Russell James
Russell James's Avatar
Two big bolts hold it to the knuckle, on the backside. Don't mess with the smaller reverse torx bolts or you'll see what a caliper looks like split in half.
Old 02-19-2013, 08:49 AM   #6
IH8OPEC
ΜΟΛΩΝ ΛΑΒΕ
IH8OPEC's Avatar
Drives: 2010 VR/W 2SS/RS L99
What part of Georgia are you from?
Just asking so I can avoid the area , Brakes are not the best thing for a novice to be messing with IMHO!
IH8OPEC is offline   Reply With Quote
Old 02-19-2013, 09:15 AM   #7
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Two bolts, one brake line. Install by pushing the pad on top of the piston back in a bit, then install over the rotor, reconnect the brake line (you will have to bleed the brakes afterwards), then reinstall the two bolts previously removed.
Never step on the brake pedal with the caliper removed or the brake line disconnected. Do not get brake fluid on anything painted.
This is the Reader's Digest version. Read about it before attempting, making sure you understand every step.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
brake, brake caliper paint, brembo, calipers
