Old 03-05-2013, 04:52 PM   #1
SERVED_USMC
SERVED_USMC's Avatar
Drives: Slow
Any 427 LS3 guys running a TVS or Whipple setup? *Update* ECS Ysi
Just trying to get a plan going for the end of the year. The car just got off the dyno and put down some decent numbers for an N/A car. I would like to put a blower on it this fall and am wondering what the outcome for everyone else was.
Motor is a forged TSP LS3 427 stroker, 238/248,CnC'd heads, Fast 102 with a NW 102 TB and American Racing header. Put down 516/496 to the tires.
I wouldnt want to go any more than 8psi on a conservative tune. At the end of the day she will see more street time than track and want the tune to reflect that.
7April2013 Update
Been going back and forth with Nick and Straightline Performance for the last few weeks trying to get a setup nailed down. With his help and many phone calls, I think weve got it.
As of now, here is how it should sit within the next 6 weeks.
UPDATE 24April2013
Just got off the phone with Chris@ECS. YSI kit is ordered, should be at Straighline in a couple of weeks. Going to call Matt@FPS and get the meth kit, gauges, booster pump and a set of ID1000's ordered and sent to Straightline as well.
Im hoping that everything will be installed in about a month. I should have some dyno video up by then.
Thanks to everyone for the help.
SERVED_USMC is offline   Reply With Quote
Old 03-05-2013, 04:56 PM   #2
jrpxxii
jrpxxii's Avatar
427 is alot of motor for the smaller blowers and you will want to swap out cams for a blower cam
Old 03-05-2013, 05:10 PM   #3
Moreno1
Drives: G5.R
What compression are your running?
Moreno1 is offline   Reply With Quote
Old 03-05-2013, 05:22 PM   #4
SERVED_USMC
Drives: Slow
I assume the bigger c.i. is harder on the unit?
Cam is still a 114 separation. Still going to be a problem?
Old 03-05-2013, 05:22 PM   #5
SERVED_USMC
Drives: Slow
11-1 per Texas Speed.
Old 03-05-2013, 06:06 PM   #6
jrpxxii
jrpxxii's Avatar
With bigger ci it requires alot more blower to move that much air. For what you are looking for it will probably be fine. Your compression is pretty high as well but running on lower boost will be a little easier on the motor as well.
Old 03-05-2013, 06:13 PM   #7
SERVED_USMC
Drives: Slow
Any other suggestions on what I should start researching based on what Im looking for?
Old 03-05-2013, 06:18 PM   #8
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Its not the cubes that are hard on the blower. Its trying to spin it fast enough to get the boost up to any decent power level.
On my LSX 427, my D1SC is too small for this motor and lots of belt slip at 5300rpm. I managed to get about 11 or so psi out of it but i need more CFM to get me to my goal. Twin Turbos here i come!
I think your cam will be fine, just not optimized...Contact Pat Guerra and he can spec you out a cam based on what you plan to run and your eventual goals
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-05-2013, 06:59 PM   #9
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I was told by a few builders that taking the LS3 to 427 the cylinder walls would be to thin for boost. I can not confirm this just what I was told when looking into it.. Might want to call TSP and ask them.
Nitroman28 is offline   Reply With Quote
Old 03-05-2013, 07:10 PM   #10
SERVED_USMC
Drives: Slow
Thats who I spoke with. I called them up before I bought the car and had a discussion about it after I told them I may want a power adder after I get it. Based off of their shortblock he said that I could run 10psi or a 150shot reliably.
ETA: He did say I could push it a few psi more, but couldnt guarantee that it would have the longevity of only run 10 or less. After that discussion I figured that 8psi would be a very safe number to shoot for.
Old 03-05-2013, 07:18 PM   #11
BullF-16
BullF-16's Avatar
If you look at the texas speed motors. They hone the walls only to 4.07" but stroke it up to 4.125" So no issues with cylinder walls. Basically same bore as a 416 cube. I dont know the ramifications of running the stroke all the way up to 4.125 however
Old 03-05-2013, 07:32 PM   #12
SERVED_USMC
Drives: Slow
I dont recall who I spoke with over there, but from what he told me...
The stroked 427's are not as problematic now as they were when they were first introduced. The piston skirts used to not be suitable for such a long stroke. Since then, most companies have redesigned, or changed, their pistons with a longer skirt to accommodate the 4.125" stoke of the 427 kits.
He also said most of the problems that are talked about with the 427's came about long before the problems were addressed, but are still spoken about as if they are still a common problem. Again, he was speaking for TSP and not another builder.
Old 03-05-2013, 07:35 PM   #13
Nitroman28
Nitroman28's Avatar
I thought it only took 4.100 with that bore to get 427? I thought the 4.125 was closer to 440?
Old 03-05-2013, 07:49 PM   #14
BullF-16
BullF-16's Avatar
4.125" stroke honed out to 4.07" is 429 CI, this is how the website describes it. For the 427 it is 4.07" bore stroked to 4.1"
